AH FabricationsJMB Retrofits
    Oct 2004
    Southampton, England
    86
    2.6 V6 fuel pump
    does anyone supply replacement or uprated fuel pumps for the A4? cant find any listed, and pretty sure mines on its way out. [img]/ubbthreads/images/graemlins/thumbsdown.gif[/img]
    imported_VaulterTim
    Re: 2.6 V6 fuel pump
    I bought one of these... ATP Walbro 255 litre/hour Fuel Pump
    T
    Oct 2004
    86
    it says drop in replacement but from what i know the electical connector is deffinately different
    imported_VaulterTim
    Fezz,
    It comes with a connector and flying leads that you can crimp into the existing wiring, hardly difficult [img]/ubbthreads/images/graemlins/tongue.gif[/img]
    What IS difficult though is removing the damn pump!
    Jeez!
    You need a special tool but you can do it without if you have the patience... it remains to be seen whether or not I do [img]/ubbthreads/images/graemlins/grin.gif[/img]
    Will be fitting it soon, when I do the turbo install.
    (I can't believe how long I've had the kit and I've still not fitted it!)
    Tim
    Oct 2004
    86
    will have to wait till my co-worker move to Audi then rob the special tool me thinks.
    no crimping a connector isnt difficult but im lazy! get fed with working on cars all day.
    have to wait see how much you struggle fitting yours before i buy one think.
    you know if ATP have adapted the pump to fit or if its standard walbro?
    imported_VaulterTim
    It's a standard Walbro pump in a custom CNC billet aluminium surround designed to fit straight into the original fuel tank mounting point. They also do one for the transversely mounted engines. Different mounting surround shape...
