    audi-a6's Avatar
    Aug 2011
    christchurch
    487
    2.7t boost problem
    This is actually an a6 2.7t but similar to s4 and get more response here
    Not sure if turbo('s) have gone or i got boost leak, have not tested for leaks yet as just so busy. boost used to hold 1.3 with lots of power, but now struggles to hit 0.8 even when it does in 3rd gear or above it dips down to 0.4 and wont come back up until i reset ecu or just restart engine only code i get is 17964 negative deviation or boost limit not reached..... iv attached 2 videos 1 is just mainly so you can hear the noise the turbos are making the other is the same but 3rd gear run with boost cutting down to 0.4.....
    Boost 1 - YouTube
    Boost test - YouTube
    Boost 2 - YouTube
    Audi a6 2.7 bi-turbo, spax coilovers, 3SDM 19" 10j alloys, full turbo back twin exhaust with RS6 style exits, HID's, DRL's, over sized RS6 spoiler, stage 2 remap, RS4 K&N, Infinity 6x9, infinity door speakers, orion hcca 15 in custom enclosure 1 x hifonics brx2000.1 amp and 2 x hifonics brx 640.4 amps, 2 x yellow top batterys, RS4 turbos, inlet pipes, stage 2 clutch
    Blue_Thunder's Avatar
    Feb 2007
    Liverpool
    1,691
    That third clip sounds bad. It could be a huge boost leak causing the whistle, but to me sounds a little like the turbos over spinning.
    You need to get it pressure tested. If you are lucky and there is a leak and you are able to fix it, you may buy your turbos a little more time.
    Mo power, mo problems
  1. boost problems
    By mac1403 in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th December 2005, 17:16
  2. MOVED: S3 Boost Problem
    By bampy in forum The Welcome Section
    Last Post: 30th May 2004, 23:04
  3. Boost Problems!!!! New Owner So Quite Worried!!!
    By Add7 in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th May 2004, 12:50
  4. boost problems - following remap
    By tim99 in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th May 2004, 12:59
  5. S3 Boost problem
    By Mike.M in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st March 2004, 23:13
