Monster MotorsportBadger5
Results 1 to 7 of 7
    Oct 2012
    429
    Front bumper alignment
    I have been having a play today with the front bumper alignment and i am struggling to work out how to raise the sides so they sit higher up in the front wing to reduce the gap, the plastic guides on the side that the bumper clips into have no slots in them so what's the deal here or am i stuck??
    Ian
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,136
    Dont you adjust the shocks at the front to level the gap out ????
    Soupie69uk's Avatar
    Owner
    Mar 2004
    Edinburgh, Scotland
    2,751
    The plastic brackets have some bolts which can be loosened then the bracket can slide up and down.
    A4 1.8T Quattro
    Oct 2012
    429
    Odd mine dont appear to have any adjustment on them, had them off twice thought i had missed it first time round!!
    2,167
    do you have a facelift model?
    Oct 2012
    429
    no it's a 98 previous owner retro fitted facelift headlights
    Jun 2012
    Ireland
    59
    The brackets don't slide enywhere what I did on my car adjusting the bumper on the sides, remove them brackets drill a bit bigger hole and then u'll be able to move the brackets and put a washer on them bolts holding the bracket
  1. Front bumper and headlight alignment help needed
    By Daz4311 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 12th May 2012, 17:44
  2. Front bumper alignment
    Last Post: 6th May 2012, 12:56
  3. A3 Front Bumper Removal
    By RichA3Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th February 2011, 08:00
  4. A3 front bumper
    By spencerjoel in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th February 2004, 18:10
  5. Front Bumper
    By darrenp in forum A4/S4 forum(B5 Chassis)
    Last Post: 5th November 2003, 14:31
