Results 1 to 8 of 8
Thread: Loud engine...?
    Aug 2012
    37
    Loud engine...?
    I have a 2.5 V6 TDi and the engine is very loud, almost sounds just like a tractor. I know that's very vague but I didn't know if it's a common problem.
    Its not a tap tap or a knock just a loud engine!!
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,523
    high miles?
    spartacus 68's Avatar
    Dec 2008
    Aberdeenshire
    255
    The V6 is the sweetest noise you'll ever hear. Yes it can be a bit tractor-like at start up, but hey you can't have everything. Do you still have the engine under-tray in place? There is sound insulation foam padding on it, and there's the plastic V6 engine cover, again with foam insulation.
    2010 Škoda Fabia 1.6 TDI CR (105) Elegance (31k)
    2002 A2 1.4 TDI SE (130k)
    2001 A4 2.5 TDi Avant Quattro Sport, aka Amrak Locomotive (162k)
    1995 80 TDI Avant SE (175k) Sold
    Jun 2011
    Great Melton Norfolk
    1,356
    Manifolds cracked?
    wesmaster's Avatar
    Apr 2012
    Oxfordshire
    291
    Mine is a little noisy on tickover, but as stated before, check all covers in place.
    When driving the engine is VERY quiet, only noticable when pushed hard. And I have removed the pre cat and main cat.
    Aug 2012
    37
    Loud engine...?
    It's only on 130,000 miles with lots of history and the engine cover and under bonnet foam are both present - although the engine cover isn't screwed down. Would that make the difference.
    It doesn't sound like a cracked manifold, like I said its more of a diesel tractor loudness. It's having it's cambelt done at the moment and I'll try and get a video on its return.
    Jan 2011
    Aberdeenshire
    646
    Mrs PaulFs' Avant has this issue, and I've still not cured it!
    My saloon only has that 'crack' when cold for a couple of minutes.
    Other causes I have found so far are the Turbo Actuator rod length/stop screw adjustment (I'm nearly done adjusting the Avants' and will do a 'how to' when I'm done), Coolant Temp Sensor causing it to be too far advanced in 'cold mode', the return line system - copper washers and/or pipes at the injector bleed offs, pump timing - if it's too far advanced, you can get a 'bark' and pump advance solenoid.
    1999 A4 B5 1.9 TDi FWD Saloon, Green SOLD
    2000 A4 B5 2.5 TDi Quattro Avant, Maroon, 'Panzer' Plated (currently sporting wrecked engine - and gearbox )
    2000 A4 B5 2.5 TDi Quattro Saloon, Blue, 'Panzer' Plated, Cruise Control retrofitted, OEM 6 Disc Changer retrofitted
    2006 A6 Allroad 3.0 TDi Blue, awaiting stuff to be done!
    Aug 2012
    37
    Loud engine...?
    Keep me updated Mr. F!
  1. Loud buzzing noise with igintion turned (with or without engine running)
    By safc quattro in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd January 2013, 18:38
  2. Loud engine noise - CURED!!
    By Acidic32 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 24th November 2009, 08:46
  3. a3 1.8 turbo cold engine start loud screech
    By munkyman in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st April 2009, 06:04
  4. loud blowing noise coming from engine when started up......?
    By rockstar in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 17th October 2007, 17:55
  5. Loud Rattle from engine - Audi80 '93 TDi
    By LongI in forum Diesel forum
    Last Post: 11th August 2006, 19:43
