Monster MotorsportVolks Autos
Results 1 to 32 of 32
Like Tree2Likes
  • 1 Post By aragorn
  • 1 Post By qwagon
Thread: FL headlights on a PFL car
    Jan 2013
    Norwich
    127
    I'm quite keen to freshen up the front end of my PFL Avant and would like to upgrade to the projector style headlights found on the FL models. I understand that slight modification of the innards of the front wings are required to ensure proper fitment, can anyone try their best to explain this or go one better and show pics please?
    Thanks.
    '92 VW Corrado 20vt
    '98 Audi A4 Avant TDi 110 - EGR delete...
    '08 BMW 320d Edition M-Sport Touring
    'You screw up just this much, you'll be flying a cargo plane full of rubber dog sh*t out of Hong Kong'
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,134
    Facelift Projector Headlights Conversion on a Pre-Facelift
    i have a set but they are fairly weathered/dull so would need a thorough clean up/polish of the lenses, one is missing the height adjust motor and one of the caps has a hole from HID bung. You can have them for £40 posted if you want them there no use to me. PM me if interested and il get some pics over to you by email.
    Jan 2013
    Norwich
    127
    Quote Originally Posted by Bradderz_1988 View Post
    Brill, cheers dude, excellent thread.
    I'm currently looking on eBay for some good condition ones, they seem to vary a lot in price, some of which are comically priced, but budgeted to pay ideally no more than £60 for a pair, I think it's going to be tough to find but I like a challenge.
    '92 VW Corrado 20vt
    Biodiesel Purrrr
    Jun 2011
    London
    150
    plus you'll probably need an adaptor loom - £40 on ebay
    or make custom one with the PFL light plugs splicing into the old connectors.
    custom looms can be mabe using VAG catalogue parts, described here:
    Facelift Headlight Adaptor?
    sounds quite simple really
    TDi Biodiesel sippin' A4 Avant - EGR blanked
    "Cars are good but Jeremy Clarkson is a dick."
    Jan 2013
    Norwich
    127
    Quote Originally Posted by TeKnodriver View Post
    Cheers for the info. I'll probably get the pre-made looms unless the connectors are really cheap and I can source an accurate pin out for the new connector against the old wiring.
    '92 VW Corrado 20vt
    Sep 2011
    Sunny Bangor. N.Wales.
    288
    bradders, what headlights you using ATM.. i'm looking to replace my FL ones, but i fancy some of the DRL ones.
    2000, A4 2.5Tdi Quattro.
    Tinted, 3600WATTSLoud
    Aug 2010
    3,134
    Just normal headlights from a 2000 A4 i got them cheap an were in excellent nick ie lenses look brand new one is a depo and the bottom corner lug is missingbut the unit its pretty firmly secure.
    If your going to get new ones save money for the D2S black out ones, there exactly the same as oem units but black and they take the ballast etc from th S4/RS4.
    these are them but are costly as there from the states but im sure there available from somewhere in the uk !!!!
    AUDI 99-01 A4/00-02 S4 B5 BLACK HOUSING CLEAR CORNER D2S HID ELLIPSOID HEADLIGHT | eBay
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,350
    Bear in mind the US projector will be backwards compared to the UK.
    Also, the quality of the depo projectors has been known to be somewhat poor. I'd avoid personally.
    TD5 Land Rover Defender build
    Sep 2011
    288
    does anyone have a good set they'd recommend, ideally with DRL's and uk spec.
    "Stick a V8 in it!"
    15,350
    Just get normal proper Valeo units, and if you want daytime lights just switch the bloody headlights on like the swedes have been doing for about 30 years.
    TeKnodriver likes this.
    Sep 2011
    288
    I'm always on sidelights during daylight hours. . Jus fancy jazzing it up a bit
    "Stick a V8 in it!"
    15,350
    push the stalk up another click then :P
    Sep 2011
    288
    That's ok. Bit at night it is shocking. .... even with a 6000k hids-direct kit fitted. .. absolutely shocking.
    Aug 2010
    3,134
    Just found these pal might be worth a shot look weathered but id get clearer pics emailed over or get them cheap as chips.
    audi a4 front light clusters | eBay
    Jan 2013
    Norwich
    127
    Top man, cheers Bradderz! I've ping'd him an email via eBay, just waiting to here back. They look, as you say, a little dull, but there's plenty of ways to revive them and for the money can't complain really.
    '92 VW Corrado 20vt
    Arrkon's Avatar
    Midlands regional Moderator
    Oct 2010
    Coventry, West Midlands
    1,641
    Damn that's a good price
    Currently rolling in a SKODA!!!
    Jan 2013
    Norwich
    127
    Well I lost out on them
    My offer was declined and before I had chance to revise my offer they had been sold, boll*cks!
    Most breakers on eBay want £80+ inc VAT and postage for them! That's well over £100 before they hit my front door!!
    Anyone know of any others for sale?
    '92 VW Corrado 20vt
    Aug 2010
    3,134
    I have some but are fairly weathered as i said before, i can post pics tomorrow but one needs a cover and height adjuster motor say £30 posted if you want them and you think you can clear them up abit !!
    Aug 2010
    3,134
    You found any yet ???
    heres the ones i have
    they are genuine audi/valeo units one needs the dipped beam cover (n/s) and one needs the height adjuster motor (o/s) all lugs are intact have cleaned them up a bit but think they need to be done with a 'mop' to bring them up more the o/s is the worst one. Let me no !!!!
    Feb 2012
    Co. Durham
    13
    I think a bit of time with some fine grade wet and dry and some polish and they will be fine!
    Arrkon likes this.
    Jan 2013
    Norwich
    127
    Bradderz, are the missing pieces hard to source? I can't imagine people want to break a headlight down unless the lens was proper goosed.
    Cheers.
    '92 VW Corrado 20vt
    Aug 2010
    3,134
    Scrap yard would possible have a headlight that maybe smashed/damaged i can check with my local scrappers if they have them il get them if they have them and call it £40 posted ??? or the motor and cover from PFL may fit FL ???
    "Stick a V8 in it!"
    15,350
    FL motors and covers are dfiferent
    The motor is common to many vag cars though. Cover might be too?
    Jan 2013
    Norwich
    127
    I've tried every scrappy within a 40 mile radius where I live when looking for the FL scuttle trim, all they had was PFL cars and all of which had there lights gone. Parts such as lights, I would imagine, are one of the first things to go?
    If you don't mind trying to source the bits that would be much appreciated indeed. If you can find the bits so the job lot is ready to just install I'll have them off you for £40.
    Cheers mate.
    '92 VW Corrado 20vt
    Aug 2010
    3,134
    I pop up tonight see if they have anything and let you no !!
    Jan 2013
    Norwich
    127
    Cheers dude!
    '92 VW Corrado 20vt
  28. #27
    NineNails's Avatar
    Proud sponsor of the snack food industry
    Sep 2006
    North Wales
    579
    Keep looking on ebay mate and some will turn up. Consider buying them separately as well. It took me a couple of months but I ended up with 2 brand new Valeo units bought in separate auctions for a grand total of £30
    2000 1.8t quattro Sport totally standard (ish)
  29. #28
    Aug 2010
    3,134
    Called at scrappers last night and they didnt have any FL lights in just PFL im afraid.
  30. #29
    Jan 2013
    Norwich
    127
    Ok mate, thanks ever so much for asking, appreciate it. I think I'll leave it for now tbh, going to give the old girl a full fluid service, EGR delete, freshly cleaned turbo, new header tank and FL scuttle trim. So she's had her fair share of £££ spent on her this month!!
    Thanks again mate.
    '92 VW Corrado 20vt
  31. #30
    Aug 2010
    3,134
    No probs mate if you track down cover and a motor pop us a PM if you still want them.
  32. #31
    Jul 2007
    London
    3,234
    I have a pair of good facelift front lights if still interested, your's for £60 + post...Breaking a 1.8TQS w reg so all parts available !
    FOR SALE:
  33. #32
    Jan 2013
    Norwich
    127
    Quote Originally Posted by adamss24 View Post
    PM'd
    '92 VW Corrado 20vt
  1. Replies: 1
    Last Post: 21st July 2012, 10:25
  2. Bumper/Headlight Adjustment - how flush is your car front?
    By Wrath in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 23rd April 2010, 19:29
  3. Auto headlights lights off when locking car
    By navnayyar in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th October 2009, 22:58
  4. pic request... Black headlights, silver car
    By cjhill in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th April 2008, 20:30
  5. Pics of my car after upgrading headlights
    By ajmackie in forum A4/S4 forum(B5 Chassis)
    Last Post: 11th December 2004, 00:43
