Volks AutosChris Nott
Thread: Head gasket?
    Dec 2012
    20
    Head gasket?
    Hi all. I have a 1998 afn engined a4 1.9 tdi. Recently it's started losing water and I can't find a leak. I have to top up the coolant everyday. During my journey the heater doesn't get very warm and after a while will suddenly blow stone cold at which point the engine temp starts to rise above the half way mark where it normally sits on the gauge. It seems dependant on how I drive. Once the heater blows cold if I drive it hard the temp rises. If I back off and take it steady the temp falls back to the half way mark. It's had a brand new thermostat and water pump only a couple of months ago. Is there a special technique for bleeding the coolant system or does this sound more sinister like head gasket failure?
    Thanks in advance
    Dave
    tazzy baby's Avatar
    Rookie
    Feb 2009
    south wales
    545
    on my old b5 there was a bleed screw on the rad to bleed the system it was on the bottom left corner behind the bumper other than that it could be the gasket sorry fella
    If you give a mouse a cookie......
    He's gonna want a glass of milk....
    vorsprung durch technik
    Dec 2012
    20
    No worries. Thanks matey. Just wanted to check before I start pulling the head off
    Dec 2012
    20
    Once up to temp the coolant hoses are rock hard pressurised as well if this is any help
    2,165
    sounds like a head gasket failure
  1. head gasket going!!!
    By killa_z in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th December 2006, 14:58
  2. Anyone done Audi S3 head gasket?
    By myrichdad in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd September 2006, 22:35
  3. Head Gasket gone - thin caramel film on oil cap
    By VPMD7A in forum TT/TT-S/TT-RS Forum
    Last Post: 1st August 2006, 22:45
  4. 1995 S6, blown head gasket?
    By imported_BkkS6 in forum General Technical / How To
    Last Post: 6th October 2004, 17:46
  5. Head gasket wear in time?
    By FrOgR in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th June 2004, 15:06
