EM TuningSky Insurance
Results 1 to 20 of 20
Like Tree1Likes
  • 1 Post By Bradderz_1988
Thread: Unusual engine noise...
    Arrkon's Avatar
    Midlands regional Moderator
    Oct 2010
    Coventry, West Midlands
    1,633
    Guys, noticed an odd noise today...
    A "tick tick tick" that increases frequency with engine rpm, sounds similar to either a plastic flap or possibly a shorted HT spark click, but no obvious impact on engine running. Sounds more localized to the inlet manifold area...
    Any suggestions on what to check? Can't find anything obvious.
    Currently rolling in a SKODA!!!
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    2,875
    I noticed something similar near runner 1 @ injector but wasnt really that fussed as could only hear it with my head literally over it, only other thing is check its not coming from back of the valve cover as this could mean the pick up is starting to block up snd not enough pressure to get the oil to the CCT also check all pipe work check valves solenoids etc easiest way is get a screwdriver or 3/8 extension bar and just place it on s few components and listen through it like a stethoscope if thats how you spell it lol see if the noise is more audible through it !!
    Mods - Frankenturbo F4 Kit - THS Decat - Milltek - ECS Crank Pulley - 034 Snub + Bracket/Gbox Mounts - 1Z/S2 Clutch + Flywheel - 007p - ICM + EVAP Delete - S4 B6 345mm Brakes - 300mm Rear Brakes - Goodridge Hoses - LCR Splitter -S4 Bumbers + Skirts/Mouldings - OEM Xenons - Apikol Diff mounts - Polytek'd Rear Diff Mount
    To do - F21 Upgrade - 3" Maf/Saab red Injectors
    WANTED : Cheap 02/52 Passat 1.8T AWT Manual
    Arrkon's Avatar
    Oct 2010
    1,633
    doesn't sound like its the CCT, sounds further forward than that. its quite prominent, can hear it outside of the car with the bonnet shut...
    Aug 2010
    2,875
    Use my method above see if you can pin point it to a certain component/area. oh and check the classifieds theres an S4 bumper with your name all over it lol
    Iceash's Avatar
    Mar 2012
    Brightlingsea
    390
    Quote Originally Posted by Arrkon View Post
    I've got exactly the same from time to time comming from the are box though. Quite odd.
    Arrkon's Avatar
    Oct 2010
    1,633
    Quote Originally Posted by Bradderz_1988 View Post
    Will have a nose around tonight...
    Yeah seen it mate, unfortunately with my WB conversion and new turbo, funds don't allow for it at the mo
    Arrkon's Avatar
    Oct 2010
    1,633
    Aug 2010
    2,875
    Iceash if yours is near the airbox it may be the purge canister solenoid valve they do tend to tick will be louder if the nipple or pipes are split/cracked.
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,357
    bent rod?.....
    Arrkon's Avatar
    Oct 2010
    1,633
    Quote Originally Posted by Byzan Pics View Post
    bent rod?.....
    Thanks got me panicking now lol
    Odd thing is, it's gone away now lol, comes back intermittently...
    Iceash's Avatar
    Mar 2012
    Brightlingsea
    390
    Does that ticking change speed then?
    Aug 2010
    2,875
    One of the Aux pulley bearings ?? ageing belt ?? Sticky injector ???
    bent rod ..... whats one of them lol
    Aug 2010
    2,875
    Quote Originally Posted by Iceash View Post
    not to sure but i would of thought so as the engine pulls more air the ecu will open the solenoid more so i would at a guess say yes it should.
    Iceash likes this.
    Iceash's Avatar
    Mar 2012
    Brightlingsea
    390
    This is also my guess its defo coming from the airbox area
    Aug 2010
    2,875
    Take the airbox cover off and where the aircon pipes emerge in this area there will be a brown solenoid on the airbox with two wires going to it with 2 pipes either side one goes into the wing one to the turbo inlet pipe have a listen to the solenoid and have a 'GENTLE' poke at the pipes not to rough as the solenoids break down and ten to snap the nipples as i found out so i just bodged it as a new one is £75 from dealers, so if anyone has one spare and wants to post it me feel free lol
    Iceash's Avatar
    Mar 2012
    Brightlingsea
    390
    I'll wait till it gets noisy all the time only notice it now n then. Least I know it's working. ABS is on my hit list then the dash. Think my Module has a crack in the connection somewhere. As it trips the Red Warning light then goes straight out. Stupid car lol.
    Aug 2010
    2,875
    sounds like it maybe one of the abs reluctor's has cracked on one of the rear driveshafts have you checked these ??
    Iceash's Avatar
    Mar 2012
    Brightlingsea
    390
    funny you say that. There is a crack in One of them as it pulses when you come to a stop. Just never set the abs alarm off before
    Aug 2010
    2,875
    It may have weathered/corroded slightly and increased the gap so the abs maybe picking it up id get it clamped up and spot welded to the shaft and then she what happens.
    Iceash's Avatar
    Mar 2012
    Brightlingsea
    390
    Good point well made. :-)
  1. Engine noise - ???
    By sinbadfury in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 13th February 2006, 15:09
  2. Diesel Engine Noise
    By S4_dan in forum Diesel forum
    Last Post: 15th January 2006, 07:57
  3. engine noise on start up
    By S3JUS in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd November 2004, 18:43
  4. TDI engine noise
    By vwed1 in forum Volkswagen and other VAG
    Last Post: 23rd October 2004, 00:12
  5. Engine Noise in 4th and 5th
    By BiffS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th October 2003, 08:41
