Chris NottEM Tuning
    Dec 2012
    47
    Audi A4 B5 estate Rear shocks and coils replacement
    Hi, I need to change the rear coils and shocks on a B5. The car seems a bit too firm without much travel in the suspension so i think it might be a bit worn out and one of the shocks has oil leaking from it. Is this an easy job to replace them and do you have any tips or guides for this? I'd like to put the softest coils and shocks in as possible for a comfy cruiser...any suggestions where to go for them? Many thanks!
    2,175
    They are easy to do, but you have to remove the rear interior panels so you can access the bolts holding the shocks in place. There are only 3 bolts you need to remove 2 at the top behind the trim panels and one at the bottom. I would look to replace the bottom bolt & nut as it would be very rusty state.
    I've got a pair of standard SACHS springs, you can have for £30 + postage, they have been on the car for just over 6 months, I only replaced as I have just fitted a full set of eibach sports springs. I also got a brand new SACHS standard front springs for sale
    B5 BIKER's Avatar
    Jul 2011
    GALWAY, EIRE
    241
    Watch out for the alloy bolts that hold the top mount in place. Can be very soft.
    Sheared 2 of mine when re-tightening, as they seem to be a soft alloy metal
    Dec 2012
    47
    Hiya!
    Thanks for the message. Would they fit with standard gsf shocks if i get some of those? Do i need to compress them down to fit them? Many thanks
    Dec 2012
    47
    Quote Originally Posted by B5 BIKER View Post
    Thanks for the tip!
    2,175
    Quote Originally Posted by Johnjones View Post
    Hiya!
    Yes they would fit as they are standard springs, you would need spring compressors to fit front & rear springs (unless your going for a slammed look)
  1. DIYT fitting rear shocks and springs, 2002 S3
    By JD09 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th September 2010, 23:59
  2. Rear shocks and springs
    By sp84 in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th June 2010, 11:21
  3. 332 for Oem Rear Shocks and Springs Exc VAT!!!!!!
    By Forbzeeee in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th February 2010, 10:10
  4. Scraping Noise from rear? Brake and pad replacement? or stone stuck?
    By parin in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th June 2009, 19:29
  5. Rear shocks and bushes
    By t30gue in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd July 2004, 10:41
Tags for this Thread
