Volks AutosMonster Motorsport
Results 1 to 10 of 10
    Jan 2013
    Norwich
    127
    Smokey under acceleration
    Was after people's take on why this is?
    I appreciate that the car is nearly 15yrs old and isn't as squeaky clean when it rolled out the factory but when I give it full throttle to about 3-3.5k and look back it looks horrendous, especially at night. Is there anything you can do to reduce this?
    Cheers.
    '92 VW Corrado 20vt
    '98 Audi A4 Avant TDi 110 - EGR delete...
    '08 BMW 320d Edition M-Sport Touring
    'You screw up just this much, you'll be flying a cargo plane full of rubber dog sh*t out of Hong Kong'
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    2,866
    Cataclean ??? Block of the egr and clean turbo vanes with mr muscle and a good service.
    Mods - Frankenturbo F4 Kit - THS Decat - Milltek - ECS Crank Pulley - 034 Snub + Bracket/Gbox Mounts - 1Z/S2 Clutch + Flywheel - 007p - ICM + EVAP Delete - S4 B6 345mm Brakes - 300mm Rear Brakes - Goodridge Hoses - LCR Splitter -S4 Bumbers + Skirts/Mouldings - OEM Xenons - Apikol Diff mounts - Polytek'd Rear Diff Mount
    To do - F21 Upgrade - 3" Maf/Saab red Injectors
    WANTED : Cheap 02/52 Passat 1.8T AWT Manual
    Jan 2013
    Norwich
    127
    Quote Originally Posted by Bradderz_1988 View Post
    Cataclean? What do you mean?
    I plan to do the EGR delete, is the turbo easy to get off?
    Thanks.
    '92 VW Corrado 20vt
    Aug 2010
    2,866
    You dont need to remove the turbo to do the mr muscle clean but if you want to its not to bad of a job, cataclean is a addative you put in to the fuel tank.
    CATACLEAN CATALYTIC CONVERTER CLEANER 475ml NEW!!! | eBay
    Jan 2013
    Norwich
    127
    Nice one, cheers dude.
    Is there a guide, with pics, for this turbo clean?
    Saved the Cataclean stuff in the watch list on eBay, will defo get some of that for sure!
    '92 VW Corrado 20vt
    Sep 2012
    Bamfurlong Wigan
    199
    Add scr8pdo on Google+
    Mine does this terribly lol, off the mark say up to 3k it pulls dead quick, but over rev it and it splutters and pumps out some severe fog, mine has no CAT any more but Iam told it needs the EGR delete and the inlet manifold unclogging and the turbo giving the Mr Muscle treatment, iam just waiting for a decent weekend, I was hoping to do this at this weekend but the weather looks to be horrendous near us on Fri til Sunday.
    If I go for a blast on the motorway, the car will run/pull fine as long as I change up before around 3k, if I go above that it hesitates and feels restricted as if the air has been cut or blocked so I assume its well carboned up within the inlet side of things
    Biodiesel Purrrr
    Jun 2011
    London
    150
    I get only a bit of smoke under full load,
    the only time it was throwing out black smoke under load was due to overfuelling from boost leak in holed intercooler
    now there's a slight haze that can be seen in the car behind's headlights on full acceleration
    to blank-off the EGR on an AFN or AHU engine the steel plates are on ebay - you will need 2 plates and remove the corrugated stainless tube connecting manifold to EGR.
    TDi Biodiesel sippin' A4 Avant - EGR blanked
    "Cars are good but Jeremy Clarkson is a dick."
    Jan 2013
    Norwich
    127
    Quote Originally Posted by TeKnodriver View Post
    I think to not get some smoke under full load be very unusual especially considering the car's age and diesel technology. Going to buy the Darkside Development kit for the EGR blank, will post pics etc when I get time to fit it.
    '92 VW Corrado 20vt
    Jan 2013
    Norwich
    127
    I think to not get some smoke under full load would be very unusual especially considering the car's age and diesel technology. Going to buy the Darkside Development kit for the EGR blank, will post pics etc when I get time to fit it.
    '92 VW Corrado 20vt
    Biodiesel Purrrr
    Jun 2011
    London
    150
    Quote Originally Posted by MaverickTDi View Post
    not that there is no smoke - as in previous post what I mean is itis only visible as a haze between my car and the car behind when headlights are on.
    there is smoke, particularly if it has not been floored in a few days, but not clouds of black smoke visible under accereration all the time.
