JMB RetrofitsBadger5
Page 2 of 2 FirstFirst 12
Results 41 to 57 of 57
Like Tree1Likes
Thread: EGR blank & inlet mani clean
  1. #41
    Jan 2013
    Norwich
    127
    Quote Originally Posted by ScottB5 View Post
    If you are keeping the EGR valve. lease the hose alone, if you are removing the valve, then blank the hose off.
    For the ease and simplicity of things I'll shall just be blanking off the EGR thus removing just the flexi pipe and leaving the valve and hose connected.
    '92 VW Corrado 20vt
    '98 Audi A4 Avant TDi 110 - EGR delete...
    '08 BMW 320d Edition M-Sport Touring
    'You screw up just this much, you'll be flying a cargo plane full of rubber dog sh*t out of Hong Kong'
  3. #42
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,003
    Here's some close up pics of my engine covers and EGR blank.
    Skuttle tray and battery cover.
    ABS, washer cover.
    Smaller air box cover.
    Larger dimple air box cover.
    EGR Blank.
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
  4. #43
    Jan 2013
    Norwich
    127
    ABS, washer cover.
    EGR Blank.
    That's ace cheers mate!
    Ordered the Passat dimple engine plastics via TPS, I collect Monday. Could you take a pic of where you modified the PAS cover to fit over the pipes?
    EGR will be very similar to yours but I'll be leaving my EGR valve in situ. Received my other free VAG blanking plate from Darkside this week, happy days!
    Think I've found someone via eBay who's just started to break a FL car and all the scuttle plastics etc, he tells me, are there, just waiting to hear back on a price.
    '92 VW Corrado 20vt
  5. #44
    Jan 2013
    Norwich
    127
    Scott, where did you get your oil & expansion caps from, look nice. Seen the R8 ones but the expansion cap in £50!
    '92 VW Corrado 20vt
  6. #45
    Biodiesel Purrrr
    Jun 2011
    London
    150
    Quote Originally Posted by MaverickTDi View Post
    This is the way to go for simplicity and price!
    TDi Biodiesel sippin' A4 Avant - EGR blanked
    "Cars are good but Jeremy Clarkson is a dick."
  7. #46
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,003
    Re: EGR blank & inlet mani clean
    The caps are from Porsche. I use to sell them but passed the Raines on to Hecktor.
    Drop him a PM or Look up WOT motorsport on facebook.
  8. #47
    Jan 2013
    Norwich
    127
    Cheers dude, just PM'd him, so hopefully I'll hear something back.
    '92 VW Corrado 20vt
  9. #48
    Jan 2013
    Norwich
    127
    Small update,
    I've offered up the Passat engine bay plastics;
    The airbox trim fits a treat, I can see where I can use an existing fixing point to secure it, plus it's a really good fit. The PAS cover, a little more complicated, as you can see in the picture I have circled, in red, 2 tabs that don't seem to have any purpose for the A4 application, do I cut these off or is there some use for them? I've also highlighted, in yellow, where I need to cut a 'half moon' shape out of the cover to allow it to surround the hose flush. Regarding the PAS cover, how is it actually secured then?
    Cheers.
    '92 VW Corrado 20vt
  10. #49
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,003
    The pass just sits there.
    The bits you got in red are cut in half and they tuck in to a slot under the slam panel. you should be able to see/feel it there.
    That's where mine sits and its not moved.
    Once you have the Facelift scuttle panel/battery cover on, that will help secure the panel as well.
    When you cut the half moon shape out, get some rubber pipe and cut a slit down it on side side to go over the plastic and help protect the rubber pipe.
  11. #50
    Jan 2013
    Norwich
    127
    Ok, fair enough. I does seem to sit fairly securely like. I'll chop the tabs down by half then as you recommend and put some protection round the bit I cut out to stop it chaffing on the hose.
    Still struggling to source FL scuttle/battery cover. I don't suppose you have VAG part numbers for them? Might just buy a piece at a time from TPS if it's not extortionate!
    '92 VW Corrado 20vt
  12. #51
    Biodiesel Purrrr
    Jun 2011
    London
    150
    Ditch the plastic and get your EGR blanked mate!
    nah, looks tidy really but did you get th plates sorted?
  13. #52
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,370
    I put all my stock plastics in the bin, and even reverted to the PFL scuttle cover on mine :P
    TD5 Land Rover Defender build
  14. #53
    Jan 2013
    Norwich
    127
    Had a spare few hours today and accomplished this;
    Passat trim, modified and fitted.
    Although both bits of trim sat fairly secure, I decided to add an inconspicuous ty-wrap point just so they didn't move.
    Airbox;
    PAS;
    Using a hole drill, I cut a half moon shape out of the side of the PAS cover so it would fit snug over radiator pipe;
    ...and finally I performed EGR surgery;
    That's all my successful efforts today, I have a rather frustrating issue regarding the CD changer install, see separate thread.
    '92 VW Corrado 20vt
  15. #54
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,003
    Nicely done that man.
    All you need now is some Porsche caps, Black washer, power and break fluid caps, black oil dip stick, new coolant bottle, break bottle, FL scuttle plate and a good clean.
    Sorted.
    lol
    Looks good.
    Covers are needed for TDIs.
  16. #55
    Jan 2013
    Norwich
    127
    Sorted.
    lol
    Looks good.
    Cheers mate,
    Sourcing Porker caps through a chap on here next pay day. Finally sourced FL scuttle trim plus wiper arms £50 all in. Coolant bottle is also next month.
    Where do you get black PAS, brake fluid and dip stick from?
    '92 VW Corrado 20vt
  17. #56
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,003
    PAS cap and dip stick is Plasti dipped.
    Brake fluid is from a pug.
  18. #57
    Jan 2013
    Norwich
    127
    Been a while since on here, busy away with work!
    Having a few hours to myself today, I decided to fit the FL scuttle plastics and wiper arms I eventually found on eBay and this is the result;
    Before;
    After;
    Next week the expansion tank is getting replaced, reconditioned turbo fitted and I'm treating the old gal to a oil service.
    '92 VW Corrado 20vt
  1. TDI Inlet mani cleaning Question
    By bez101 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 20th August 2012, 20:57
  2. Audi A4 1.9tdi EGR blanked and Inlet Cleaned
    By craigg9700 in forum A4/S4 forum(B5 Chassis)
    Last Post: 21st May 2011, 22:12
  3. EGR and Inlet Manifold clean
    By QuottroA4 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 7th March 2010, 15:52
  4. Inlet Manifold Cleaning
    By samuelt in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 28th August 2008, 21:11
  5. EGR Blanking cap
    By james0808 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st December 2006, 14:45
