Chris NottMonster Motorsport
    2,178
    Can some confrim the speed pulse wire on the face lift instrument cluster
    Trying to confirm which is the speed pulse wire on the on the facelift instrument cluser, elsawin states "Blue Multi-pin connector. Pin 3 - Speedometer (output 1)". I've check the connector and there is a wire (white/blue) connected to pin 3 and on the power connector block on the symphony in pin 1 it's white/blue yet when I put a meter across the 2 it shows open circut. I just waht to make sure I'm on the right pin before I run a new wire.
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,523
    white blue is correct. Bare in mind it probably runs thru the dash between where you have connected at dash end. You need to trace the Gala wire
    2,178
    Thanks, just wanted to confirm. I'm just going to tap into the wire at the instrument cluster end and run a new wire to the plug just need a quick fix for the next couple of days, until I get some daylight over the weekend.
  1. where is the speed sensor wire please help
    By JA50N in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th April 2012, 18:39
  2. guys who did the mod how much are those face lift center dash buttons?
    By drnutta in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th November 2011, 23:19
  3. can some 1 tell me how to remove the lighter socket
    By sean3794 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th November 2010, 10:37
  4. Speed Pulse wire
    By belabed in forum In-Car Entertainment
    Last Post: 22nd July 2005, 21:49
  5. Some good news on the speed camera front
    By imported_Yaseen in forum General Chat
    Last Post: 24th June 2005, 14:50
