AH FabricationsChris Nott
    Nov 2012
    48
    Wheel offset question
    Hi all,
    Would 8j 17" alloys with an offset of ET48 fit my A4 without any problems?
    Many thanks,
    Grant
    Jan 2013
    Norwich
    127
    Quote Originally Posted by Grant_H View Post
    Hi all,
    Many thanks,
    Grant
    What is the original wheel offset? Only reason I ask is I'd personally stick with an ET figure as close to the original as possible. Remember the lower the ET number the further out the wheel/tyre will sit from the centre line of the car, the higher ET the closer. You may also need to think about wheel spacers if your looking to achieve a certain 'stance'? If you find a set of wheels with the same ET as original wheels and go for a slightly different width, say 8j and your originals were 7j you'll find they might stick out a bit, therefore if you go for a wider wheel consider a higher ET?
    I'm by no means a wheel expert, so if anyone else wants to weigh in please do so.
    jcb
    Sep 2005
    uk
    4,070
    what tyre profile and brand?
    i would personally say it might be a struggle
    wrong tyre choice puts you very close to the upright
  1. Wheel offset question
    By Blackie in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 23rd March 2011, 22:31
  2. Wheel offset question
    By Audijarvis in forum A4/S4 forum(B5 Chassis)
    Last Post: 1st June 2010, 09:36
  3. Quick Wheel Offset Question
    By stevereid in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 31st March 2010, 20:19
  4. Wheel offset question
    By Syncopix in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th March 2010, 19:10
  5. Wheel Offset Question
    By Hatmeow Sportback in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th May 2007, 16:19
