Badger5JMB Retrofits
Results 1 to 20 of 20
Like Tree1Likes
  • 1 Post By Bradderz_1988
Thread: Need hids but which ones??
    Chriscooke's Avatar
    Clueless!
    Mar 2012
    Taunton
    403
    Ive had enough of the poor excuse for headlights on my qts. Can people with experience please link me to some good value and effective kits, im looking at 6000k kits currently as thats whati have fitted in my other car and love them..
    Is there a how to guide on here anywhere?
    Arrkon's Avatar
    Midlands regional Moderator
    Oct 2010
    Coventry, West Midlands
    1,641
    Can't say I've seen a HID how to on here, but can reccomend a company called HIDs direct near Manchester. Go for 5 or 6000k for the best light output.
    Though fitting is really easy gimme a shout if you need a hand mate
    Currently rolling in a SKODA!!!
    B5 BIKER's Avatar
    Jul 2011
    GALWAY, EIRE
    241
    I know people will tell you to use genuine but it's not always possible.
    I have fitted some from halk alarms. They are their own branded kits with a 2 year warranty
    on the ballasts and the lamps. I have 6k on my avant and the light output is excellent.
    Have them for about 14 months now with no issues and plug and play install so only takes about an hour to fit.
    From what I remember I think they cost about 40-45 a set, so good value
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,505
    4300 is the best output, make sure they have cancellers fitted as the ballast resistors help prevent bulb out warnings and flickering
    Oct 2012
    492
    I had a cheap 6000 kit in my old passat about £30 of eBay they were very good I had the car 6 years never had any bother with them I would of put them in my a3 by now but been put of by wiper motor stories
    Chriscooke's Avatar
    Clueless!
    Mar 2012
    Taunton
    403
    Cheers guys, only part I'm worried about is removing the headlights but expect itll be obvious when I actually look.
    Sep 2011
    Sunny Bangor. N.Wales.
    288
    changing the bulbs to HID's easy, you'll know what to do, also there's a recess under each lamp for the ballasts :D
    2000, A4 2.5Tdi Quattro.
    Tinted, 3600WATTSLoud
    B5 BIKER's Avatar
    Jul 2011
    GALWAY, EIRE
    241
    Quote Originally Posted by Chriscooke View Post
    Dont think you will need to remove the headlamps, I didn't anyway.
    The hid ballast normally has two leads, one connects to the existing bulb plug
    and the other connects to the new bid bulb.
    You will probably have to drill a hole in the plastic cover after you take it off the back of the headlight.
    And then fit a rubber grommit which is normally supplied to keep the headlight waterproof
    Oct 2012
    492
    You shouldn't have to remove the lights no
    Chriscooke's Avatar
    Clueless!
    Mar 2012
    Taunton
    403
    same as the nissan then, happy days.cheers for the tip about balast fitment
    205man's Avatar
    May 2006
    worcestershire, uk
    1,016
    You can fit them without taking the lights out but if you want to mount the ballasts in the proper tray under the lights then you will need to take the lights out which also means taking the bumper off etc.
    do you have face lift head lights? As of course you need projector lens
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,113
    You dont need to remove the bumper to remove the headlights i did mine the other week and you can just about get them out, personally ive always used cheap kits and the ballasts seam to go when the temp drops, personally if you can get a set of genuine s4/rs4 units for a good price then id do that then just swap out the DS2 4300 bulbs to the 5000 DS2's, i must of bought 2 sets and 2 replacement ballasts so id do it proper first time.
    205man's Avatar
    May 2006
    worcestershire, uk
    1,016
    I thought facelift headlights have a screw hidden underneath below the bumper line? So that why you have to remove the bumper.
    I'm not sure about pre facelift lights though
    Aug 2010
    3,113
    Facelifts have a bracket that the lug on the head light sits in the other bolt is behind the indicator of the headlight which is accesible with a long extension and socket then you can just about clear it past the bumper and out. Cant remember if PF are the same style.
    205man likes this.
    205man's Avatar
    May 2006
    worcestershire, uk
    1,016
    Thanks for the info as was going to fit new ones to mine this weekend, I was going to take bumper and fit new alternator belt at the same time, but if I can do it with bumper in place then i might forget the belt lol
    jcb
    Sep 2005
    uk
    4,077
    Hidsdirect
    install:
    HID install (picture heavy!)
    done!
    Chriscooke's Avatar
    Clueless!
    Mar 2012
    Taunton
    403
    Cheers for the link mate, seems straight forward enough
    Chriscooke's Avatar
    Clueless!
    Mar 2012
    Taunton
    403
    What bulb fitment is on the face lift qts?
    Aug 2010
    3,113
    H7 pal
    Chriscooke's Avatar
    Clueless!
    Mar 2012
    Taunton
    403
    Legend, cheers mate.
  1. CCTV To Watch Over Car But Which One?
    By emzino in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th March 2007, 12:56
  2. Buying an A4 but which one
    By sean.ui in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th October 2006, 13:09
  3. The A3 might be going for a Diesel... but which one?
    By Markb in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th June 2006, 19:51
  4. Upgrading to a new b6...but which one?!
    By imported_Audi_DavE in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 17th January 2006, 23:50
  5. Ok, it needs chipping, but which one?
    By S3BeemerBeater in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th March 2004, 13:24
