EM TuningVolks Autos
Results 1 to 8 of 8
    Jan 2013
    Exclamation audi newbie with hissing noise after engine shuts off
    hi all, i have just brought an a4 which has been standing for a while 11 months ish, just had new mot on it, and drives amazing, its around 150k but drives like a much younger car, main question is
    when i switch off engine after a run there is a hissing noise from engine bay seems to be from expansion tank area.
    the length of time can vary not seemingly related to the length of drive.
    also have had a couple of times when temp sensor reads 60 on motorway then returns to 90 but not ever over in traffic???
    oil temp never seems to rise above 60 either??? am i missing something??
    please help am totally now an audi man but just learning the ropes
    regards luke.
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,460
    Welcome to audi-sport.net Luke. The guys will help you with advice. Happy New Year and enjoy the forum. x
    NineNails's Avatar
    Proud sponsor of the snack food industry
    Sep 2006
    North Wales
    579
    Hissing will be the air-con so don't worry. Prob best turn it off this time of year. Mines bust and I don't miss it
    2000 1.8t quattro Sport totally standard (ish)
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,372
    It could also be a bad seal on the expansion tank cap. Have a closer listen, if its the AC it will be coming from the battery area, rather than from the expansion tank itself.
    The temperature thing is probably the thermostat, get a new one fitted.
    TD5 Land Rover Defender build
    Jan 2013
    Question air con or should i say climate control grrrrrrr
    hi guys
    yep its air con many thanks
    just discovered wet foot well last night, it seems after looking on forum its prob a blocked drain, i hopee to god it aint matrix!!! altho i dont loose any coolant yet:-)
    i need to change front and rear brakes and discs got a quote for org spec
    front discs(pair) 60 inc
    rear discs (pair) 38 inc
    front pads 42
    rear pads 23
    i was thinking of upgrading but not got loads of cash, is it worth using grooved/drilled do they actually make a big diff say over just a better make of standard disk??
    any advise please.
    many thanks again
    luke
    Sep 2011
    Sunny Bangor. N.Wales.
    288
    for brakes, look up MTECH BRAKES.... i cant fault them or their prices...... :D
    2000, A4 2.5Tdi Quattro.
    Tinted, 3600WATTSLoud
    Jan 2013
    kilmarnock
    12
    Hi
    I have the same problem with my air con also , my car put the air con on its self and costing me a fortune in fuel i wonder if there is a fuse that i can pull to stop it ??
    Sulli79's Avatar
    Oct 2010
    Surrey/Berkshire
    495
    Quote Originally Posted by solarstu13 View Post
    Hi
    Press the econ button on your climate control unit, that switches off the ac, you may need to press it again after selecting another mode
    1999 1.8TQS Saloon in Black/Dirt
    1999 1.8TQS Saloon in Silver Breaking
  1. Noise after ignition turned off
    By MrTackalakalaka in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th May 2012, 17:21
  2. engine shuts off in a weird way
    By khalil in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th January 2012, 13:07
  3. Help with tick tick noise from engine
    By imported_ashs3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th September 2009, 17:33
  4. Noises after Engine Stops....?
    By Eddie123 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th March 2008, 14:48
  5. Standard Audi Alarm with after market one?
    By Markb in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th March 2005, 21:24
