Badger5JMB Retrofits
Results 1 to 9 of 9
    Nov 2003
    114
    wipers are getting slow, and have now stopped !!???
    any ideas why my wipers got really show and have now stopped all together!??
    Jul 2005
    Lancashire
    43
    Re: wipers are getting slow, and have now stopped !!???
    The same happened on my A3, its probably the spindles and mechanism getting all manky. It needs taking apart, cleaning and reassembling. Should be OK after that.
    RichA3Turbo's Avatar
    ...Watching you!
    Earlsfield, London
    5,087
    [ QUOTE ]
    [/ QUOTE ]
    unles its like mine and seized beyond repair...where even a sledge hammer won get the spindle out of the housing! lol.
    Rich
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,851
    Same happend to me. I bought a second-hand unit and fitted that.
    It a late model problem as the older A4's don't have this problem.
    Nov 2003
    114
    right, so was it the wiper motor docurley?
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,851
    No its the frame, the joints just seize up, if you dont fix it soon your knacker the motor.
    Also when you do it mark it with tippex or a marker pen at each nut and position as your have a nightmare if you don't.
    I learnt the hard way.
    mac1403's Avatar
    Sep 2005
    wales uk
    956
    Hi...The linkage on mine siezed too. It is a common fault especially on A4's. I was told by the dealers it would be the motor, so be aware they are not always right. Also if you get one from a breakers like I did that they give you the right one. The motors have different electrical connections. As I said, lucky for me it was just the linkage so I could swap the motors and just use the new linkages.
    Nov 2003
    114
    fixed last night, thanks for ur help all and yes it was the drives side linkage, it was SOLID.
    you have to remove a wee circlip and then hammer the spindle appart, and grease it up
    Sep 2003
    medway,kent uk
    103
    mine has done this twice now, the first time East kent Audi quoted me 160 for a new linkage but stripped it down and regreased it for nothing. [img]/ubbthreads/images/graemlins/bravo.gif[/img]
    now all i do is regually put some 3 in 1 onto the spindles and that works fine
