Volks AutosEM Tuning
Results 1 to 12 of 12
Thread: 2.5tdi
    No Gear
    Dec 2012
    Shropshire
    216
    2.5tdi
    A4 2.5tdi 1999. The charging light flickered for a few days and now stays on 90% of the time going off occassionally. Can a duff battery cause this or is it most likely the alternator?
    Steve B5 Biker's Avatar
    Jan 2012
    SOUTH YORKSHIRE
    120
    Had exact same issue, and like you thought it was battery at first,turned out alternator goosed, bought a refurbed one problem sorted.
    NineNails's Avatar
    Proud sponsor of the snack food industry
    Sep 2006
    North Wales
    577
    Is it not possible just to change the brushes and rectifier on these units?. I know on older ones you could...
    2000 1.8t quattro Sport totally standard (ish)
    No Gear
    Dec 2012
    Shropshire
    216
    The brake servo pump is leaking oil. Is the alternator below the pump on the left side of the engine?
    Maybe oil has contaminated the brushes? Is it worth spraying some cleaner into the alternator or
    would that be a bad idea?!!!
    Jul 2007
    London
    3,072
    Alternator goosed, will require bumper removal and front panel in service position...
    FOR SALE:
    No Gear
    Dec 2012
    Shropshire
    216
    I'm told the aircon pump needs removing to gain access to the alternator is that correct?
    Well impressed with this site, learnt lots tonight definately buying some mr muscle tomorrow!
    No Gear
    Dec 2012
    Shropshire
    216
    Drove into town yesterday battery light off, all ok. On start up to come home battery light on constant.
    To remove the alternator will I get sufficient access by sliding the front panel forwards on a couple of
    rods or will it need shifting out of the way?
    Also, what's the crack with the aircon pump?
    Thanks.
    No Gear
    Dec 2012
    Shropshire
    216
    Drove car again today charging light off for a few miles then on. When I got home took the airbox and
    Intercooler hose off, the alternator is covered in oil and muck. Looks like the cam cover is leeking. I
    released the black connector holding 2 wires bluish in colour I think. On feeling the back of the alternator
    it feels like another cable on a crimped eyelet type connection which I didn't remove.
    When I examined the 2 bluish coloured wires 1 of them had a small bit of insulation missing exposing a bit
    of conductor. Wow I thought found the problem! After taping the cable put it all back together and ran the
    engine but light still on.
    Took black connector off and using a mutimeter found both cables common to earth which surprised me.
    Then with one probe on battery positive I touched the engine with the other probe and meter went beep which
    stunned me! I hooked the meter across the battery and with it beeping away I removed each fuse in turn but
    it beeped constantly. My next idea was to disconnect the neg and pos from the battery to see what effect that
    had but suddenly the problem went away!
    Any thoughts people?
    Also how I've described the alternator is it bosch or lucas?
    If only it was like my old capri or cortina! 10 minutes to change an alternator!
    Jul 2007
    London
    3,072
    It's a Bosch...
    FOR SALE:
    No Gear
    Dec 2012
    Shropshire
    216
    Thanks at least I know which model the alternator is now. I may as well source a replacement
    in case I flog the car.
    Is there another forum with electrical boffins on it don't seem to be getting any feedback?!!
    No Gear
    Dec 2012
    Shropshire
    216
    Just stuck my car on ebay ! Can't be doing with the grief!!!
    Pictures on album on my profile page.
    No Gear
    Dec 2012
    Shropshire
    216
    Ebay rocks sold it!
  1. New 2.5TDi Quattro Tip =O)
    By TheTonsta in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 12th October 2003, 17:32
  2. SOS - HELP BUYING A6 2.5TDI or 1.9TDI 1997+
    By Wallstreet in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 15th September 2003, 18:47
  3. A6 Avant 2.5tdi quattro sport Tiptronic
    By jyeoman in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 24th August 2003, 16:39
  4. A4 2.5TDI Cabriolet
    By TonyB in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 2nd June 2003, 21:38
  5. Audi A4 Cabriolet 2.5TDi
    By amoffat in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 14th January 2003, 03:28
