Chris NottEM Tuning
Results 1 to 8 of 8
    Nov 2012
    49
    2.5 tdi de-sludging?
    Hi all,
    After fixing the beeping noises in the dash, I thought I'd turn my attention to preventative maintenance; namely the sludge problems associated with audi long life servicing.
    I've recently drained some jet black oil and re-filled with 10w/40 semi-synthetic with new oil filter. A week later and this 'new' oil has also gone black!
    Is there any way of safely de-sludging the pick-up pipes etc without taking the pan off and without using any harsh additives, etc?
    Regards,
    Grant
    Jul 2007
    London
    3,247
    Get used to it, the diesel oil gets black very quick. As long as it's fresh then it does not matter ! I would switch to a fully syn. 5w40 oil and drop it every 5-6k if you want the engine to last !
    FOR SALE:
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,383
    If you change the oil 3 or 4 times in succession, driving the car for a few miles between each change and ensuring the oil gets fully up to temperature (ie a decent long journey of 20-40miles rather than 5minute trips), this will clean the insides out without resorting to anything harsh.
    Just use the cheapest mineral oil you can find, Wilkos does some 10w40 stuff for about 12 quid a gallon.
    As Chris says deisels do tend to have fairly dirty oil, but giving it a good clean out should see it staying golden for a bit longer than a week!
    TD5 Land Rover Defender build
    spartacus 68's Avatar
    Dec 2008
    Aberdeenshire
    255
    I use Castrol Edge 5w30 fully synthetic oil and it's black in next to no time! I change it every 10k with a genuine Audi oil filter. When changing the oil, always get the car up to temperature (having dropped the plastic engine guard first), then pull the sump plug. Fit a new copper sump washer before refilling. You can also remove a little used engine oil from the oil filter housing using a syringe.
    2010 Škoda Fabia 1.6 TDI CR (105) Elegance (31k)
    2002 A2 1.4 TDI SE (130k)
    2001 A4 2.5 TDi Avant Quattro Sport, aka Amrak Locomotive (162k)
    1995 80 TDI Avant SE (175k) Sold
    "Stick a V8 in it!"
    15,383
    It will be on 10k changes.
    The issue even on a healthy diesel engine thats run on "normal" oil change intervals is that the inside of the engines covered in a film of black manky oil. When you fill it with fresh stuff, the manky stuff quickly dissolves into the new fresh oil turning it black. At which point you then drive on it for 10 thousand miles making the insides all manky again.
    A few changes in quick succession will remove all that really dirty oil thats hanging around, and it will stay clean for a while. You'd need to drop to 2-3k change intervals to KEEP it like that though i'd imagine.
    Dec 2008
    Aberdeenshire
    255
    Not with Castrol Edge at £35 for 4 litres, and the V6 lump takes just under 6 litres!
    Nov 2012
    49
    Cheers for the advice guys!
    Will there be any need to physically clean out the pickup pipe at all?
    Jul 2007
    London
    3,247
    Quote Originally Posted by Grant_H View Post
    Nope, the diesel don't suffer sludge issues like the petrol engines do...
    FOR SALE:
  1. Brown sludge 1.9 tdi
    By MarkWizard in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th February 2011, 10:35
  2. A3 TDi
    By audi_girl in forum Diesel forum
    Last Post: 12th August 2003, 09:32
  3. GOLF 110 TDI T REG
    By ooooaudi in forum Diesel forum
    Last Post: 16th April 2003, 16:52
  4. A3 2.0 TDi review in Autocar
    By amoffat in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th March 2003, 18:30
  5. A4 TDi 110 OR PD 115 Which is Best?
    By 18ME in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th January 2003, 00:44
