AH FabricationsSky Insurance
Results 1 to 9 of 9
    Sep 2011
    Sunny Bangor. N.Wales.
    287
    Question Facelift Headlights.... crap :(
    as above my audi a4 FL (1999) avant headlamps are shockingly dim.... even with a HID Conversion...... would aftermarket h/lamps (with sexy DRL's in them) be better, or would it have the same issues due to the reflectors... and is there anything i can do in the meantime....
    any help appriceated.
    Wayne
    2000, A4 2.5Tdi Quattro.
    Tinted, 3600WATTSLoud
    Jun 2011
    71
    What HID kit are you running? I have a A4 1999 facelift sport quattro with a HID conversion kit - 6000k ice white, its the ice white bit that makes them so bright, I came to the conclusion that the bluer they are and the higher the number the darker they are - mid range number is the best I find, I had mine realigned with a beam setter after fitting and they are good on a dark country road, when stopped infront of a wall at a 10 meter distance I have the perfect ''''''''''''\____ beam lines from both lights with a slight blue tinge, long distance is good too, reflects road signs from long distance before the edge of the dipped beam becomes closer to the sign, I also run osram nightbreaker plus in the full beams. The first set of HID I obtained from someone on ebay were terrible and dark, so sent them back for a refund, this set is much different and brighter.
    Jan 2012
    Malton
    272
    Lights in my A4 not up to much - however not helped by daily drive though Bilsdale - the one upgrade I would love would be headlamp washers and Volvo style wipers!
    Sliver 2000 1.9 Tdi AJM Se Auto Saloon cooking sherry but with CD Changer and now Bluetooth audio connection and boot based Tartan blanket. Now runs at 90 degrees like a good 'un
    Silver 2000 2.5 V6 Tdi Auto Quattro Saloon drowned on 7th August 2012 RIP
    Arrkon's Avatar
    Midlands regional Moderator
    Oct 2010
    Coventry, West Midlands
    1,633
    I found that refurbishing the lens face made a significant difference. That reminds me, need to do it again.
    Like this: rayray's garage: DIY: Headlight refurbish
    Currently rolling in a SKODA!!!
    Sep 2011
    287
    i too have a set of H7 6000k HID's in mine, again like you i have a lovely line and "kick" associated with the headlights, also had the headlamps adjusted but still the output is shocking, altho a few friends comment on how bright they are until they come for a drive with me, then they say how bad they are.
    Jun 2011
    71
    All I can say is perhaps its the quality of the set you purchased - I think you do pay for what you get, if you pay around £20 to £30 I expect them to be quite poor in output like the first set I purchased, so I went more up market and payed around £80 and they are far better quality with a higher brighter output, the pictures they use on ebay are not necessarily what you will see when you put them in your own headlights.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,905
    Most aftermarket kits have utter ****e lamps compared to genuine 4300k HID's as supplied by reputable companies.
    Most of these kits use cheaper salts which produce light in the 6000k> range, which your eye is much less sensitive to due to the increased amount of blue wavelengths. The genuine lamps are more expensive due to the salts required to produce decent quality light. The Halogen projectors also arent upto the job of properly spreading an HID lamps beam in the correct way and the focal point will be different too.
    If you want good performing HID's you need good 4300k lamps (Osram or Philips, though trying to find genuine Philips ones these days is like hens teeth) and projector assemblies that are designed appropriately for the HID lamps. The missus A4 has a fake Philips lamp in one of its headlamps and the output from it is rubbish compared with the genuine one on the other side.
    I've bought a set of FX-R BiXenon projectors to retrofit to a spare set of halogen headlamps for my car, but i've just not got round to it yet.
    TD5 Land Rover Defender build
    jcb
    Sep 2005
    uk
    4,070
    HIDsdirect
    have two sets and they are pretty good
    still very bright after some years
    had one faulty ballast replaced under warranty
    suspect as always eBay specials are the lower end of the market
    Sep 2011
    287
    That's where I got mine... as they are in Irlam, Manchester I popped over.
  1. Facelift Headlights fitted...
    By RichA3Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th January 2006, 12:54
  2. Facelift headlight guys....
    Last Post: 6th January 2006, 23:34
  3. facelift headlight alignment
    By ultramodz in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th August 2005, 23:44
  4. Facelift headlights
    By imported_highlander1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th October 2004, 13:09
  5. 225 facelift headlights
    By ravi in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th May 2004, 08:26
