Sky InsuranceJMB Retrofits
Results 1 to 11 of 11
Thread: Concert II Swap
    gmx
    Feb 2009
    Sydney
    133
    Concert II Swap
    Finally got a Concert II from an A3 (8P0 suffix). Apart from fascia, is there anything else to swap to complete the mod?
    Is DIS good to go or needs a some pinning/wiring?
    I also have an XCarlink adapter which I assume will work since the stacker plug is the same?
    The car is a 11/99 build digital clock.
    00 A4 1.8TQS GP MT AJL
    JHM SSK | FX300 + 16lbs FW | Milltek Dump back
    17*8 BBS RK | Deka ETX20L | Vogtland GT 575F/675R | H-Sport 35mm(F)/22.5mm(R) ARBs
    034 Engine Mts | Stern Snub/ Rear Diff Insert/Power Ring
    GT2871R Elim | Custom ME5 | 034 3" DP | 034 HFM | 034 TIP | ER Comp IC
    Sulli79's Avatar
    Oct 2010
    Surrey/Berkshire
    492
    Quote Originally Posted by gmx View Post
    You will need a canbus adaptor from kufatec.de, or similar, think the kufatec one is about 80 euros
    http://www.kufatec.de/shop/media/images/popup/453_0.jpg
    dont know if any coding is required after?
    1999 1.8TQS Saloon in Black/Dirt
    1999 1.8TQS Saloon in Silver Breaking
    Sulli79's Avatar
    Oct 2010
    Surrey/Berkshire
    492
    2,152
    You may not need a can-bus simulator, most/all facelift B5's have infotainment can-bus on the instrument cluster however you will need run two wires can-high & can-low to the back of the cluster (from memory the infotainment pins are 5 for for can-high and for 6 can-low, but I would check that!) You may also need to change the coding, see if it would accept A4/A6 coding as you these cars don't have can-gateway.
    Sulli79's Avatar
    Oct 2010
    Surrey/Berkshire
    492
    Does the infotainment do the lighting and ignition though? I didn't think it did?
    2,152
    It will, however if you retrofit RNS-E the clock is always out so you would need something called a (google search "Bjarne CANGate")
    Sulli79's Avatar
    Oct 2010
    Surrey/Berkshire
    492
    Result, I imagine with the digital clock you will be can bus ready then,
    gmx
    Feb 2009
    Sydney
    133
    Ok I'm guessing it's these:
    Grey 32 pin connector:
    5 - CAN high speed display (high +)
    6 - CAN high speed display (low -)
    Anyone know if these terminate in the footwell somewhere or underneath the ECU area?
    ​Just looking for a clean area to splice from and run to the centre console area... and would like to avoid messing with the cluster connector area.
    Looking at this diagram, I'm not sure which pin it's suppose to go to? Are they unoccupied in the B5 and require a pinning tool?
    2,152
    As I said in my post they will not be any infotainment wires running from the cluster, you will need to get pins from kufatec or harness repair wire from Audi.
    gmx
    Feb 2009
    Sydney
    133
    Quote Originally Posted by B5NUT View Post
    Is there a link to the harness from Audi or a PN?
    gmx
    Feb 2009
    Sydney
    133
    Ok, just to test fitted it since I need to modify the faceplate (rather than buy an A6 one etc) and sometimes the front speakers don't play.
  1. Concert stereo swap?
    By James 33 in forum A4/S4 forum(B5 Chassis)
    Last Post: 21st November 2012, 14:11
  2. Very very confused RE: Concert -> Aftermarket swap!
    By Routledge in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st December 2011, 16:38
  3. Concert to Symphony II+ swapping over?
    By podiopie in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd September 2009, 02:44
  4. Replies: 0
    Last Post: 7th December 2007, 19:28
  5. Concert-2 swap...
    By imported_mc119856 in forum In-Car Entertainment
    Last Post: 17th November 2005, 17:12
