    a4-er's Avatar
    Feb 2012
    21
    How to change the coil?
    I have an a4 avant 1.6 2001 mod.
    Yesterday i was driving, then the light for electronics lamp started blinking and the engine started to shake and got a loss of power. Got home and i opened the hood. It was dark. But something was glowing red. Guess it was the exhaust pipe or something. I then used the torque app to scan for faults. I got cylinder 4 missfire. Tried swaping the sparkplugs for cylinder 3 and 4. Cleared the faultcodes. Then started the car. Same problem then. Scanned again. Then got cylinder 1 and 4 missfire.. I wonder. Could it be just the plugs. Or can it be the ignitioncoil?. Never worked much on cars. So is there alot of work to change the coil? Anyone who has a good description on how to do it? Searched the net. But could only find for audi cars with different engines then i have.
    Dec 2012
    You can defiantly start by changing the plugs, they are inexpensive ~$10 for 4
    jcb
    Sep 2005
    uk
    4,077
    unplug the MAF and do it again before you waste any time on plugs and coils
    I had the exact same issue 12 months ago.
    a4-er's Avatar
    Feb 2012
    21
    Re: How to change the coil?
    Changed the coil and wires and plugs. Its okay now. Was afraid the catalyst got destroyed too, but it was fine.
  1. How to change the gear knob/stick & gator.
    By PNH80 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th February 2013, 15:53
  2. how to... change the clock?
    By dares_uk in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th April 2009, 15:06
  3. How to change the AIRVENTS on a3 ?
    By 029kid in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th June 2007, 11:13
  4. How to - Change the side repeater bulb
    By darko in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th April 2006, 20:10
  5. Replies: 0
    Last Post: 4th August 2005, 22:47
