AH FabricationsEM Tuning
Results 1 to 7 of 7
    Oct 2012
    385
    A4 2.8 V6 30v Thermostat Replacement
    I am just wondering if this can be done without having to remove the cambelt, if so has anyone done it and how easy is it??
    Ta
    Ian
    paul74's Avatar
    Dec 2012
    Birmingham
    I need to do same job it can be done without removing cambelt the housing for the stat is located just nxt to sump nut 4 bolts holding the housing in and stat is in there replace and refit as before. Good luck save ££££££
    Jul 2007
    London
    3,077
    Quote Originally Posted by Ian2012 View Post
    Ta
    Ian
    no mate, you need to remove the belt in order to change the stat as it's under the belt on driver side. The belt needs taking off the cam pulley. I have done loads of them and it's not going to fit under the belt whilst tensioned...
    FOR SALE:
    Oct 2012
    385
    So i presume if i marked everything up in various different places with tippex and then slackened the belt it's happy days with access to the bloody stat?? provided nothing moves pop belt back on check tippex marks rotate motor for good measure by hand and voila or is that way too simple???
    michaelg1001's Avatar
    Apr 2012
    Sheffield
    99
    I've just been reading up on this on SRS for my S4, theres a lad on there who has done his by just sliding the belt forward enough to get access to it without actually having to remove it. If I knew it was such a pain in the arse I'd of got mine done a few weeks ago when I had my belt done!
    Jul 2007
    London
    3,077
    Quote Originally Posted by michaelg1001 View Post
    Done a thermostat on a c5 audi a6 with the 2.4 30V engine yesterday. I had to take the belt off. Use a genuine thermostat and seal + make sure you have the right antifreeze. I usually do replace the thermostat on v6 engines for 100 supply and fit or 80 quid with your parts...
    FOR SALE:
    Oct 2012
    385
    Any tips or tricks you could share to make my life easier??? I have stat and seal that i bought for another car but never fitted, my mpg is rediculous right now because of this
    cheers
    Ian
  1. Thermostat replacement
    By cadoc in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th November 2009, 17:32
  2. v6 30 valve thermostat replacement
    By yendall24 in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th September 2009, 12:42
  3. S4 thermostat replacement
    By stapo69 in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th January 2009, 01:29
  4. thermostat replacement......help
    By cornish_a3_turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd November 2008, 22:10
  5. Thermostat replacement
    By robonmac in forum Classic Audi Forum
    Last Post: 1st April 2007, 23:17
