    Dec 2012
    22
    Audi A4 1.9 TDI 1998
    Hi i have the above car. Not sure if its a B5 or B6 (no idea what these are)
    The drivers door doesn't catch on the keeper correctly so i have to shut it softly for it to catch or slightly lift it up on the door handle. Any ideas on how i adjust the door so i can raise it? Does the door have to come completely off? Or is there an adjusting screw somewhere?
    Jul 2007
    London
    3,258
    Check for wear in the pin on the hinge, also if the window frame or regulator has been tampered with, the door won't close properly, there are a few wedges that need adjusting in order to get a good seal from the door. Is your car a high mileage ? I suggest you take it to a bodyshop, they have experience in lining/stripping panels so may be able to adjust it for you...
    FOR SALE:
    Dec 2012
    22
    Quote Originally Posted by adamss24 View Post
    Thanks for that. Yes had it 13 years from new! Its done 164,000 now and still drives like a dream. I'll take it to a body shop then & see what they can do.
  1. Audi A6 2.5 tdi 1998 Loss of power
    By Beez in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 5th April 2010, 22:54
  2. Audi A6 TDI 1998 Wet Carpet
    By jonchold in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 4th March 2006, 15:38
