Monster MotorsportChris Nott
    ScottD3's Avatar
    Nov 2010
    Plymouth
    15,031
    Another Live Feed?
    I'm after an alternative live feed for the equipment at the back of my car.
    I'm currently using the ignition live from the panel under the steering wheel, X31 or somthing.
    This works fine when the ignition is on but I need something that works when the ignition is off but the key is still in the barrel.
    Is this a separate feed or a series of relays and what nots that turn's the radio off, lights on, unlock the car and sounds the buzzer when your lights are one?
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,389
    You can pick it up at the back of the ignition barrel, or i believe its also fed to the central locking pump, so you could get it there?
    I wouldnt run anything from it directly though, run it via a relay.
    TD5 Land Rover Defender build
    ScottD3's Avatar
    Nov 2010
    Plymouth
    15,031
    I might have to do that then.
    Bugger, I was hoping I could get away with not having to do much more wiring lol
  1. Scuttle panel removal and live feed..........
    By Dani_B19 in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st May 2011, 02:31
  2. Ingition Live Feed
    By Marc1 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st September 2009, 00:37
  3. Permenent Live Feed
    By AndrewUkR6 in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st December 2008, 20:36
  4. retrofitting Bluetooth, Live feed question
    By Marcyboy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th January 2008, 17:20
  5. S3 - Audio Switched Live Feed
    By col6821 in forum In-Car Entertainment
    Last Post: 19th June 2006, 21:08
