Another Live Feed?
ScottD3
Supporter
Plymouth
Website
wheelsnwires.blogspot.com
I'm after an alternative live feed for the equipment at the back of my car.
I'm currently using the ignition live from the panel under the steering wheel, X31 or somthing.
This works fine when the ignition is on but I need something that works when the ignition is off but the key is still in the barrel.
Is this a separate feed or a series of relays and what nots that turn's the radio off, lights on, unlock the car and sounds the buzzer when your lights are one?
You can pick it up at the back of the ignition barrel, or i believe its also fed to the central locking pump, so you could get it there?
I wouldnt run anything from it directly though, run it via a relay.
I might have to do that then.
******, I was hoping I could get away with not having to do much more wiring lol
751
36
I
731
imported_rosssummers
I
