Volks AutosAH Fabrications
Results 1 to 14 of 14
    Nov 2012
    49
    Loud beeping whilst driving - but no warning lights?
    Hi all,
    Driving home tonight and the dash was beeping every so often; 3 beeps and then occasionally a single beep.
    I know that 3 beeps is a serious fault, but there were no accompanying warning signals on any of the dash lights or the LCD. I've also ran VCDS lite and no codes show up. Any ideas?
    Regards,
    Grant
    Nov 2012
    49
    Update - same happened again tonight. Didn't happen this morning though.
    Still no warning lights; and I've also checked the MFD is working as it scrolls through it's options when the button is pressed.
    Regards,
    Grant
    Jun 2011
    Great Melton Norfolk
    1,349
    get it scanned with vcds
    Nov 2012
    49
    Hi,
    Have done - see above
    Regards,
    Grant
    Jun 2011
    1,349
    lite only checks certain modules, unless it is registered have a look here,
    Ross-Tech: VCDS: Function Table
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,372
    Things that make the Beeps wont appear on vcds.
    TD5 Land Rover Defender build
    Jan 2011
    Aberdeenshire
    646
    It sounds like the dash insert board, and I'd recommend getting it fixed sooner rather than later. I used ECU Testing the second time after a bad time with BBA Reman
    Mrs PaulFs clock set was returned from a repair doing this, and at the same time nothing was displayed.
    When a rock went through the sump, the first indication was the engine stopping as we didn't notice the genuine beeps in amongst the random ones. A remanufactured 2.5TDi and turbo was not cheap.
    1999 A4 B5 1.9 TDi FWD Saloon, Green SOLD
    2000 A4 B5 2.5 TDi Quattro Avant, Maroon, 'Panzer' Plated (currently sporting wrecked engine - and gearbox )
    2000 A4 B5 2.5 TDi Quattro Saloon, Blue, 'Panzer' Plated, Cruise Control retrofitted, OEM 6 Disc Changer retrofitted
    2006 A6 Allroad 3.0 TDi Blue, awaiting stuff to be done!
    Nov 2012
    49
    Hi there,
    Thanks for the reply! Is this an easy DIY fix?
    Regards,
    Grant
    Jan 2011
    Aberdeenshire
    646
    Yes, you take the instrument cluster out, pack it and post it off with around 150-200 beer tokens.
    When you get it back, put it back in. You'll find something doesn't work - usually fails to start and run. Then take it out and refit the plugs at the back properly.
    The insert comes out easily - lower the steering column to the lowest setting first to get the maximum clearance for removal. The there is a slide-off cover at the bottom of the cluster, this hides the 2 torx (can't remember the size, but not big) screws. You then fettle it out forward enough to unplug the connectors. They have a little latch to lift first. This latch is why you will not fit one back properly first time!
    Nov 2012
    49
    Lol thanks for the reply
    Is that all that needs doing then? Just taking out and re-fitting?
    Thanks again,
    Jan 2011
    Aberdeenshire
    646
    Sorry, I've not been clear, the steps are:-
    Taking out, sending away to get repaired at a cost of £150-200ish ​then refitting.
    I used ECU Testing, a quick check on here will give you other companies if you want.
    Nov 2012
    49
    Ahh, I'm with you; so it's a fault with the actual board?
    Jan 2011
    Aberdeenshire
    646
    Most likely - unless somebody else on here has a better idea.
    Call ECU Testing and see what they say - they may test it first at a cheaper rate.
    Another word of warning - don't think it is easier/cheaper to get another cluster.
    You need the correct one, and it needs to be coded as the immobiliser is built into the cluster. The coding procedure needs a code, extracted from the cluster. It is easy enough with the correct software (NOT VCDS) but essentially impossible without.
    The easy key programming method you get on the internet requiring two keys and a sequence of locking/unlocking only code the remote to the central locking.
    Nov 2012
    49
    Update - problem fixed!
    I re-set the service interval as well as remove / reconnect everything. The red multiplug felt a bit loose; so might've been down to that.
    Thanks to everyone for their replies
    Regards,
    Grant
  1. Egr valve blanked but now warning light
    By L3WJX in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 14th October 2012, 11:08
  2. A4 B5 bleeping, but no warning lights
    By ihs61 in forum General Technical / How To
    Last Post: 19th November 2011, 20:59
  3. warning light & beeping help
    By gemark in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th March 2009, 23:40
  4. OIL WARNING LIGHT BUT PLENTY IN????
    By veccyj in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 8th December 2007, 12:07
  5. ABS Warning Light On, but no fault
    By nomadx in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th September 2007, 18:08
