AH FabricationsSky Insurance
    Oct 2012
    390
    B5 quattro rear cv boot change
    I need to do one of these whilst doing the shocks on the rear i have boot that's holed, what's the best way to get the shaft out please??
    Ta
    Ian
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    2,883
    Easiest way is to drop the rear arm undo the 6 spline bolts and the one on the hub then push the hub outwards and pull the full shaft n/s is alot easier than the o/s as i found when replacing the rear diff seals, it makes it easier on the n/s if you drop the exhaust heres a pic to give you a better understanding of what i mean
    Mods - Frankenturbo F4 Kit - THS Decat - Milltek - ECS Crank Pulley - 034 Snub + Bracket/Gbox Mounts - 1Z/S2 Clutch + Flywheel - 007p - ICM + EVAP Delete - S4 B6 345mm Brakes - 300mm Rear Brakes - Goodridge Hoses - LCR Splitter -S4 Bumbers + Skirts/Mouldings - OEM Xenons - Apikol Diff mounts - Polytek'd Rear Diff Mount
    To do - F21 Upgrade - 3" Maf/Saab red Injectors
    WANTED : Cheap 02/52 Passat 1.8T AWT Manual
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,941
    You can also undo the top bolt on the upright, and swing it forward for clearance, rather than undoing the lower arm!
    TD5 Land Rover Defender build
  1. S3 Rear Diff Oil Change
    By jonS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th February 2007, 20:09
  2. A4 Avant 2.5TDI Quattro rear springs - where?
    By tonycaterham123 in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th July 2006, 13:16
  3. ABS keeps kicking in at low speeds? Only since CV boot change tho?
    By Charlies604 in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th January 2006, 13:12
  4. A4 Quattro Rear Diff Seals
    By kipps in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th November 2005, 18:50
  5. A3 Quattro Rear Diff/Haldex Coupling Oil Change
    By imported_rob911 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th August 2004, 10:50
