EM TuningSky Insurance
    Nov 2012
    7
    Oil Control Light
    Hi, I was driving along and the engine jerked and after about half a mile, the Oil pressure control light turned on, I stopped and turned off the engine, turned it back on and everything was fine, and then after about another 40 miles the car was running on low revs for a moment and the control light came back on. Switched ignition off, then on and it's back to normal. The car runs normally and there seems to be nothing wrong with it at all. Does anybody know what this might be? I have the 2000 Audi A4 1.8T B5 with 125000 miles on the clock. I also scanned the car with VAG-COM and no faults came up.
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,135
    Oil pick up will be blocked you will need to remove the sump and clean both the sump and pick up or it may even be worth throwing a new pump on whilst everything is off, i wouldnt risk driving it as it could damage the turbo or even worse lock up the engine my mate got unlucky he was racing down the bypass and his 1.8T passat just locked up within seconds of the light coming on.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,370
    Defo change the pump.
    For the effort involved in stripping everything down, you're just as well doing the pump from the start.
    TD5 Land Rover Defender build
    spartacus 68's Avatar
    Dec 2008
    Aberdeenshire
    254
    Interesting thread here from Audifans. New family bus. - Audifans.net
    2002 A2 1.4 TDi SE (125k)
    2001 A4 2.5 TDi Avant Quattro Sport (155k)
    1995 80 TDi Avant SE (175k) Sold
    Nov 2012
    7
    Okay, thanks for the advice! Does anyone know HOW to replace the Oil pump and where it's located?
    Aug 2010
    3,135
    Oil pump is in the sump on the right hand side of the block sort off inline with the oil filter is best way to describe it. Just take the sump off unbolt it and bolt the new one up and make sure you use 5w40's fully synth oil
  1. Traction Control Light coming on intermittently...
    By imported_Stewart in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th May 2006, 21:55
  2. Heater control lighting
    By AndyHolmes in forum A4/S4 forum(B5 Chassis)
    Last Post: 22nd September 2005, 16:54
  3. Traction control light staying on
    By monty77 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th March 2005, 15:59
  4. Oil warning light Min
    By imported_ashs3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th February 2005, 20:46
  5. Oil Min light
    By Benjaminimum in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd November 2004, 09:07
