Sky InsuranceEM Tuning
Results 1 to 8 of 8
    Boost fiend
    Dec 2008
    Swansea
    215
    TQS factory xenons pointing too high
    Hi folks, had a few cars flashing me and this morning a bloke got out of his car at a set of lights to tell me my lights here dazzling him, he also mentioned it looked as if they were bouncing as I was driving along?
    as the title says its a 99 (T) TQS with factory fitted xenons, how do I go about checking and adjusting then?
    When I turn them on try don't go up and down like other cars I have had with xenons, could this be a clue?
    99' A3 1.8T Sport KO3s Custom Code stage 2 - Current
    99' A4 1.8T Quattro Sport 180 - Sold
    97' A3 1.8T Sport KO3s 236 BHP - Sold
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,520
    id assume its a broken axle sensor, youd need to look and see if the arms are still connected to the wishbones. If you scan the xenon module it should show up. for now i'd adjust them to a sensible height manually for now
    Boost fiend
    Dec 2008
    Swansea
    215
    Are the adjuster arms connected to both front wish bones? I'm sure I have seen one on the driver side rear.
    Apr 2004
    12,520
    passenger side front lower and passenger side rear lower. They should have plastic little arm connected to them, but they have a habit of snapping when the balljoint siezes on the one end of it
    Boost fiend
    Dec 2008
    Swansea
    215
    Ok thanks mate, I'll have a look. For now think I'll just manually adjust them. Isit the 2 white cross head screws of the far left/right of each headlight?
    I had my timing belt done a week or so ago, front end off jobbie, do you think they have disturbed something when doing this? As I have not had a problem untill now.
    Apr 2004
    12,520
    maybe they set them back on too high on the bolts. The inside of the 2 screws does the height, the outer does the left/right
    CraigG's Avatar
    May 2008
    188
    if they were "bouncing" its possible that the light unit inside has came loose from the adjustment motors
    if it was a broken angle sensor, the "limp mode" is that it will set the lights to the lowest possible setting, and flag a code (had this on my old S4).
    Imola S4 - Bilstein B6 + Eibach Prokit, Anthracite BBS Pescara 18x7.5"
    Boost fiend
    Dec 2008
    Swansea
    215
    I haven't noticed them bouncing to be honest, xenons can give the illusion they are moving then coming towards/following you because of bumps on the road causing the beam to move.
    i have manually adjusted them for now? Seem a lot better and had no one flashing me ect. Cheers folks!
  1. will this sit too high?
    By skanky in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th August 2006, 13:22
  2. S3 Driving Position - Too High?
    By StephenBogan in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th September 2004, 14:59
  3. X-post for a friend: A3 Oil consumption too high
    By ImolaS4 in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th July 2004, 13:13
  4. New A3 Wiper Motor Replaced, Is the wiper too high
    By Rolex1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th February 2004, 20:37
  5. Too high Service Costs?
    By Naresh in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd April 2003, 19:17
