EM TuningAH Fabrications
Results 1 to 14 of 14
    Sep 2012
    42
    leaking back brake
    got a leek on the back caliper drivers side seen some seal kits on e bay but can not find the part number on the internet for the right kit can anyone help ???? car is 2.6 v6
    brasiliangringo's Avatar
    Mar 2010
    496
    Quattro ?
    Mar 2010
    496
    This should sort you out
    Bigg Red
    Sep 2012
    42
    i wish no mate just the normal 2.6e . nice one for the web site got them on there 19 £ job done thanks alot for that mate
    Sep 2012
    Bamfurlong Wigan
    199
    Add scr8pdo on Google+
    I have exactly the same problem with mine (caliper weeping) on O/S rear, mine is a 1.9 TDi, I was just going to snap up a 2nd hand caliper off Ebay, years back you used to be able to buy seal kits for everything and I often replaced seals in calipers, master cylinders and even wheel cylinders BITD on old Ford stuff, there used to be a great place just down the road from me called Romford Brake that just supplied just about anything and everything for absolutely EVERYTHING but this shop is no more.
    It even used to seal brake shoe linings you riveted to the shoes, but nowadays it seems the fashion is to throw away and buy new complete parts although I like the look of the above site
    Mar 2010
    496
    ^ not the 1st time i heard this being said and indeed it is a shame that we seem to live in more of a throw away society perhaps. You also learn nothing from fixing things (as people dont bother) and learning how they work which is often very enlightening. Shame then..
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,907
    The issue with the rear calipers is the handbrake mechanism.
    You can reseal the main piston fairly easy but removing the handbrake shaft requires a press and various somewhat specific tools.
    I've replaced the main seals on rear calipers before, but i've never been totally satisfied with the outcome, whereas a new caliper for £50 just seems much less hassle.
    If it was £200 new or £30 for a rebuild kit then sure, i'd be investing the time into doing it myself, but in reality its £20 for the seals, another £20 per caliper for pistons as the old ones are often knackered, then several hours of messing around, vs £50-70quid for a complete new caliper ready to bolt on. Its just not worth the effort.
    TD5 Land Rover Defender build
    Biodiesel Purrrr
    Jun 2011
    London
    150
    Had a pre-MOT look around the car and looks like I have a leaking rear caliper too...
    fluid on inner rim of alloy
    where are they available for £50? Murrays is quoting 4 month backorder
    having a better look at the pipes and joins tomorrow
    TDi Biodiesel sippin' A4 Avant - EGR blanked
    "Cars are good but Jeremy Clarkson is a dick."
    1,877
    Try eurocarparts & GSF car parts
    Biodiesel Purrrr
    Jun 2011
    London
    150
    ^^bump...
    anyone know of a cheap suorce for the rear calipers that is in stock?
    needed ASAP for MOT
    Feb 2012
    89
    I ordered a pair of rear calipers for my TQS(due to one leaking from handbrake mech) from Incar Motor Factors - The German Car Part Specialists. One of the best prices I could find on the net, and no surcharge/exchange. Still to be delivered as only ordered them last week(have to come from TRW in Germany), but the guy on the phone was very helpful.
    "Stick a V8 in it!"
    14,907
    I got one from ebay recently for my mums 1.8T FWD.
    Heres an example, this is an alloy one though, you'll need to confirm which type you have:
    AUDI A4 1.9 TDi TURBO DIESEL REAR BRAKE CALIPER RIGHT HAND R/H 1995 2001 | eBay
    Feb 2012
    89
    Got my new rear calipers for my TQS today, so a big thumbs up for Incar Motor Factors.
    Biodiesel Purrrr
    Jun 2011
    London
    150
    Update:
    Thankfully it didn't need a caliper,
    turns out there were ally washers where the brake pipe meets caliper i think,
    and these had corroded through.
    So, if you start to see any seeping down there i guess these washers could be on the way out?
  1. Back brake help please
    By s3gazz in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th January 2012, 21:52
  2. oil leak back of engine
    By tdi-man in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st September 2011, 15:26
  3. Replacing back Brake light bulb
    By missviper in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th July 2006, 21:06
  4. Leak in Back Footwell ( Pollen Filter)
    By Rev-head in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th April 2006, 21:42
  5. Leak in the back passenger well??
    Last Post: 29th March 2006, 19:17
