Badger5EM Tuning
Results 1 to 16 of 16
    Oct 2012
    426
    B5 quattro rear diff bush
    I think my rear diff bush is past it's best what are my options oem or an upgrade option?? whats peoples advice here.
    ian
    Jan 2012
    Malton
    276
    Do you mean the centre driveshaft bearing?
    Sliver 2000 1.9 Tdi AJM Se Auto Saloon cooking sherry but with CD Changer and now Bluetooth audio connection and boot based Tartan blanket. Now runs at 90 degrees like a good 'un
    Silver 2000 2.5 V6 Tdi Auto Quattro Saloon drowned on 7th August 2012 RIP
    Oct 2012
    426
    no the thunk noise is at the back, very reminiscent of old typ 85 and B4 q, funny thing is having driven qauttro for 20 yrs now the same faults are still there as each generation gets older.
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,115
    You need the apikol rear bushes and centre mount shoot hecktor a pm he will sort your needs you will be talking £300 notes though im going to be ordering the centre one soon thats £230 on its own first im sorting the turbo.
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,508
    £300, bloomin heck, Im going to just ignore mine and call it a design feature ,lol
    Aug 2010
    3,115
    I was thinking of just using poly sealant on the centre diff for now but had my eyes on the apikol but turbo is getting priority doug's just sent us out a new manifold then payday ill be getting the F21 upgrade.
    Jan 2012
    Malton
    276
    If you were planning to do the centre driveshaft bearing as well I have a brand new one from all German Parts which I got (and didn't fit) for my 2.5q a couple of weeks before I drowned it.
    Oct 2012
    426
    Is the bush itself available from audi, and just replace it like you would on something like an S2 A arm bush????
    Aug 2010
    3,115
    I suspect it is but will be some what near the price of an aftermarket jobbie, but my moto is why replace it when you can upgrade it ???
    Heres the apikol one.
    Apikol rear diff mount b4/b5 chassis
    jcb
    Sep 2005
    uk
    4,077
    i have the apikol (front) rear diff
    if is a very nice and sturdy piece of kit
    check the (rear) rear diff hanger. it has smaller bushes and mine were completely soft.
    I tiger sealed them to good effect when I rebuilt the rear subframe
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,324
    talking from experience here, DO NOT go too stiff on the rear end.
    I fitted alloy subframe bushes, 80shore rubber rear diff carrier bushes and tigersealed up the front diff mount, and the result was the thunk turned into a horrible clank as you went on and off the throttle. Even engaging the clutch between 1st/2nd/3rd when driving like a granny sounded like you were trying to snap the diff out the bottom of the car.
    What happens is all the driveline components begin to wear, CV's, Propshaft joints, diffs themselves etc all end up with a bit of slack in them. All of this wear means theres slack in the drivetrain, which at the moment is being absorbed by the nice big soggy diff mounts.
    I ended up swapping the rear carrier mounts out for new standard ones and that made it much more bearable. Fixing a worn CV on the propshaft helped too. I also changed the gearbox which improved it a bit more as well.
    I'd suggest new OEM rear bushes (they're only about 8quid each) and filling the front bush with polyurathane sealant is a decent compromise, stiffens it up but leaves enough slack so that it doesnt transmit horrible clanks into the floor.
    TD5 Land Rover Defender build
    Oct 2012
    426
    Ok thansk for the advice, how do you go about sealing the front bush??? and soes it last??
    Oct 2008
    Glasgow
    431
    I have the total opposite experience of these parts. I fitted billet front & rear subframe mounts, apikol diff carrier bushes, apikol diff mount, track density engine/gearbox mounts etc and my car has never felt better. I dont get any of this knocking, clunking, clanking regardless of how easily or how hard i drive my car nor do any of the people/customers i know who have these parts fitted.
    "Stick a V8 in it!"
    15,324
    Well presumably your driveline is nice and tight then.
    All i'm saying is if your already getting thunking, then its entirely possible that its NOT the rear diff mounts, and instead its caused by wear in the driveline components. If thats the case, stiffening everything up will only make the problem worse.
    Others on SRS have found similar issues as you well know, so its not like i'm alone with this.
    The stiff rear diff mounts and solid subframe also puts a lot more diff whine into the shell, although its most noticable at low speeds and mostly fades away once moving.
    Oct 2008
    Glasgow
    431
    With 130k miles on it i cant see it being that "tight" when compared with similar cars of this age/mileage.
    No one is saying you are alone on this. I was giving the other side (my opinion) based on my experience.
    I have to disagree with this point. My experience is that i have no added noise or vibration from the rear at low speed. To be honest my car just feels fresh, crisp, new & has a better ride especially when compared to how it was before. I get a rumble from the rear when going from 60mph to 80mph then all is normal. For me this is the only negative and not much of one as it only occurs under load.
    As i say this is my experience of these parts fitted to my car. Others may have experienced something similar to yourself or a slight vibration, rumble or like me a vast improvement in feel, connection front to rear, more stable at speed etc.
    jcb
    Sep 2005
    uk
    4,077
    well I am about as stiff as you can go in the rear (fnarr fnarr!)
    solid alloy subframe, apilkol, tiger seal, powerflex rear everything else
    I do get more transmission whine (tolerable)
    The clunk I used to have is still there but less obvious (I am sure it was the rear diff and or the drive shaft CV's)
    the slop on clutch engagement is much less than it was
    the best part of it IMO is the rear end feels utterly connected to the road and any fast acceleration or launch type starts do not feel like I am taking up lots of rubber slack before anything happens
    if there is slop in the drivetrain you need to invest some serious wedge if you want to remove all of it
  1. Replacing quattro rear diff seals.
    By ian52 in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th June 2010, 20:27
  2. A4 2.8 v6 quattro rear diff bush
    By audi1664 in forum A4/S4 forum(B5 Chassis)
    Last Post: 18th November 2008, 20:35
  3. anyone done the rear diff seals on an A4 quattro?
    By mas in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd January 2007, 12:54
  4. A4 Quattro Rear Diff Seals
    By kipps in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th November 2005, 18:50
  5. A3 Quattro Rear Diff/Haldex Coupling Oil Change
    By imported_rob911 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th August 2004, 10:50
