Volks AutosEM Tuning
Results 1 to 16 of 16
    Oct 2012
    385
    A4 B5 Airbag Light On No Comms With Controller
    Need some help please, my A4 2.8q has it's airbag light on and i can't get vcds to communicate with the controller to see what's wrong, i have looked at the plugs under the seats and also in the drivers side kick panel to see if there is anything amiss which there doesn't seem to be. Anything i have missed???
    I have searched the net and it points towards a knackered controller, if i get a used one does it require coding to the car??
    Ian
    griswold's Avatar
    336
    Its that time of year again, cold sets mine off in the morning, vcds wont clear it.
    I bought an airbag reset tool that does a clear code or reset the controller.
    Works for my controller error but as you cant connect to it maybe not yours but worth a try.
    Airbag ecu behind climate real pain to get to, just need the same number.
    A4 1.8T Quattro sport
    A6 2.4 Avant SE
    griswold's Avatar
    336
    A6 2.4 Avant SE
    Oct 2012
    385
    thanks for the link, just wondering how that manages to get comms and vcds can't?? i don't suppose for a minute that you are in the south east??
    griswold's Avatar
    336
    Cardiff, can you connect to other controllers?
    A6 2.4 Avant SE
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,905
    What age is your car? I have an ECU here if its the right number.
    TD5 Land Rover Defender build
    Oct 2012
    385
    it's a 98 car, and yes all other controllers i can connect to no prbs and no other codes, it does have an aftermarket radio which shouldn't make any difference (not fitted by me)
    griswold's Avatar
    336
    Airbag ecu removal.
    AudiWorld Tech Articles
    A6 2.4 Avant SE
    "Stick a V8 in it!"
    14,905
    The one i have came out of a 98, dont want much for it as i had it on ebay twice and it didnt sell. Its 8D0959655L.
    Oct 2012
    385
    Thanks for the offer will need to try and find which one i have in the car, will be back in touch
    cheers
    Ian
    brasiliangringo's Avatar
    Mar 2010
    496
    How much do you want for it ?
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,355
    I have one too I think from a PFL S4..
    I really need to keep track of my useful stuff
    Oct 2012
    385
    Airbag light still on i have checked the K line voltage on the diagnostic plug and that reads 9.5 volts so pretty much what it should be, i have removed the aftermarket radio which was nicely plumbed in, tried again to get the codes but nothing doing still, anything else i can check before ripping the dash apart to get the controller part no.
    Would i be wasting my time soldering the wires under the seats??
    Oct 2012
    385
    As an update I sourced another controller from ebay what a touch only £4.99, after a skin shredding session ( I kid you not!!) i managed to replace the old unit with the new / used one if you get my drift. We now have comms with airbag controller yippee, so cleared the faults and now i am only left with one 01218 side airbag igniter passenger side (n200) 32-00 resistance too high.
    Is the fix for this clean the contacts under the passenger seat or solder the wires togther??
    "Stick a V8 in it!"
    14,905
    yeh try unplugging and replugging the under seat connector a few times on the passenger side
    Oct 2012
    385
    Hopefully final update, fingers crossed, been out and pulled the plugs off the passenger seat popped them and and off a few times, then plied them with acf 50 which is a great spray (ain't cheap) that helps stop corrosion, deleted the code and hey presto no airbag light.
    Yesterday when i replaced the controller it's not easy on a pfl car, there is a how to out on the web that shows a fl car and removing the ashtray, on the pfl car removing the ashtray makes no difference. My wrists are well chewed up, i ended up wrapping them in gaffer tape to protect them, the plastic is well sharp where the climate and radio sits.
    I will end up zip tieing the passenger seat but it was too wet and miserable to be bothered today
    So a big thanks to all that helped, and i hope this post helps others in the future.
  1. Reset Airbag light with VCDS lite?
    By George The Diesel Head in forum VCDS (formerly VAG-COM) forum
    Last Post: 5th January 2012, 08:15
  2. Removing old seat with detonated airbag. How to? Also Airbag light?
    By Stanley in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th March 2011, 18:30
  3. abs airbag light
    By mlcadman in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th October 2004, 18:46
  4. Airbag Light
    By ajmackie in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th March 2004, 16:18
  5. Horn / Airbag light problem
    By MikeS in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th February 2004, 17:46
