JMB RetrofitsBadger5
Results 1 to 8 of 8
    Dec 2012
    20
    1.9tdi 110 hesitation
    Hi guys. Recently purchased a 1998 a4 1.9tdi avant. Since owning it ive serviced it changing the engine oil and filter, fuel filter, air filter, glow plugs, coolant, water pump and can and aux belts. The car has run fine since but within the last week I've noticed the engine is intermittently hesitant. If I accelerate gently I can hear it come on boost and then all of a sudden it stops. Almost like I've lifted my foot off the accelerator. If I back off the throttle then reapply it goes on to drive as it should. I'm not very good at explaining this issue so hope some of you may understand what I'm getting at and hopefully have some ideas as to where to start llooking thanks in advance
    Dave
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,273
    Could it be the infamous sticking variable veined turbo? I know the turbos on the old 1.9TDIs suffer from it as my mates Bora was the same. There are guides on the net for cleaning it using Mr Muscle oven cleaner. Might be worth a look.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,520
    Westicles speaks the truth. It will be VNT related,
    Scott will be along shortly, he is the resident Derv fella.
    Jun 2011
    Great Melton Norfolk
    1,349
    If you want it scanned i can do it. Im not far from you.
    Westy's Avatar
    Dec 2008
    17,273
    Quote Originally Posted by Byzan Pics View Post
    I'm starting to read up on the 1.9 TDI engine now as I'm looking to buy one next year. The VNT issue is the most common fault I know of on these engines.
    S3 Build Thread
    Dec 2012
    20
    Thanks guys. At least I know where to start now. I'd appreciate it if you could gen.heinz guderian. I'm in London until Friday night but could pop over Saturday morning if that's ok?
    Jun 2011
    1,349
    yes thats fine i will pm you my address.
    Dec 2012
    20
    Meant to mention it has the afn engine in it in case that makes a difference
  1. Turbo cut out on a 1.9TDI (110) quattro 1997
    By Beef in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th June 2012, 14:15
  2. 1.9tdi(110) not revving, help needed ASAP
    By Lex in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd March 2009, 21:21
  3. Getting more power out of 1.9TDI 110
    By daveB5 in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd September 2008, 20:40
  4. New member; A4 1999 1.9TDI 110 SE sport; pics and problems!
    By Mr K in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th July 2007, 14:00
  5. A6 1.9tdi (110) Clutch
    By xaddiction in forum Diesel forum
    Last Post: 12th September 2005, 21:41
