Chris NottMonster Motorsport
Results 1 to 8 of 8
    Oct 2012
    tamworth staffs
    19
    Exclamation which is best 2.7 tt 0r v8
    which is best s4 2.7 tt 0r v8 4.2 ?
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,136
    Depends on how you wana look at the car, personally i dont like the B6 chassis but then i wouldnt say no to a B6 S4 but would pick an S4 B5 just because its a B5.
    Blue_Thunder's Avatar
    Feb 2007
    Liverpool
    1,693
    Best for what? Sound? Tunability? Stock Power? Potential Power? MPG? Known engine faults?
    Mo power, mo problems
    Jul 2007
    London
    3,240
    The 2.7TT engine has more power potential with many examples in the states and mainland europe, just search for MRC or Unit 20 if you need to see what a souped up engine can do.
    The b6 platform has a touch more class and handles a bit better than the b5 platform however is heavy and does not have that much power for the displacement...
    FOR SALE:
    colicabcadam
    2.7tt by far
    getting any real power gains out of the v8 will cost you 13k (supercharger)
    2.7tt wont depreciate much more, if at all, the newer one will, as for handling, a decent set of arb and shsock spring setup will make it night and day
    Jul 2012
    Guildford
    97
    the 2.7tt (albeit the RS4 version) is the highest power engine per CC that Audi have ever produced I beleive.
    Jul 2007
    London
    3,240
    Quote Originally Posted by HibiscusS4 View Post
    The pikes peak s1 had a max power of 1400 Bhp but it started ripping the crank apart hence they have detuned the engine to just 1100 Bhp. Not bad at all from a 2.2 engine !
    Walter Rorhl used to shift in to 6th gear in 200 meters, do a search for "umluft" if you need to find out more...
    FOR SALE:
    colicabcadam
    even out does the new rs6 in that sense !
    thing is, not many engines can cope with a 100% increase in torque and a 75% bhp increase without the engine internals being changed
  1. Which is best, Call of Duty or Brothers in Arms for PC
    By ToneDeaf in forum Video Gaming
    Last Post: 8th August 2006, 16:28
  2. Downpipe size, which is best?
    By LaSarthe&Back in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th July 2006, 08:11
  3. Which Roofbox best fits my 3 door A3?
    By funkycat in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th August 2005, 12:48
  4. ISP - which one best value for money??
    By Naresh in forum Home Cinema, Hi-Fi and Gadgets
    Last Post: 12th June 2005, 01:45
  5. A4 TDi 110 OR PD 115 Which is Best?
    By 18ME in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th January 2003, 00:44
