AH FabricationsChris Nott
Results 1 to 7 of 7
    Andyb5's Avatar
    Nov 2012
    62
    Can Led bulbs cause engine management light to come on??
    As the title says really, i have brought some canbus (error free) or supposed to be any way side light bulbs off ebay took the headlights out today to fit them look lovely but within 20 mins of fitting them my engine management light had come on? Anyone else had this problem before?
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,525
    unrelated systems, you need to scan for faults
    Andyb5's Avatar
    Nov 2012
    62
    Did have to unclip part of the air box to get to one of the crews on the headlight could i have done something then? Just seems really weird 20 mins after doing the bulbs it came on? Doesn't seem to be any loss of power or anything still runs as before
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,138
    Check all your connections round the airbox. You may have left something a miss.
    Jul 2012
    Guildford
    97
    Cant see it being the problem but I have seen something very similar in the past and everyone including myself said then that it cannot happen. A friend of mine had a ford Ka and had the 2 rear light clusters replaced with European spec ones to get the car registered aborad (headlights had been done months before but he didnt realise you had to swap the fog light from right to left). After the lights had been changed his engine manegement light came on and the car started to run quite badly. It turned out that the main loom earth is at the very end of the loom and the last thing on the loom is one of the rear lights and the bolt had not been done up enough.
    Andyb5's Avatar
    Nov 2012
    62
    Well just been downstairs checking all the connections in and around the air box. i decided to take it all out and refit it just to make sure I wasn't missing anything. Fired her up and no engine management light so looks like I may have disturbed something around the air box hopefully that's sorted it. Now all my other lights look yellow with lovely crystal white side lights so just order a complete set to replace all the other bulbs with nice white xenon ones. Thanks for ur help all much appreciated
    205man's Avatar
    May 2006
    worcestershire, uk
    1,016
    you didnt have to buy canbus error fix bulbs as the sidelights arent connected to the lights out warning.
    and led side shouldnt given you a warning anyway, ive been running led sidelights in mine now for about 3 years with no problems or warnings.
    but glad you got it fixed now
  1. Engine Management Light has come on after turbo replacement
    By vinceremedy in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st March 2010, 16:14
  2. Engine Management Light on all Week now off again
    By MingBluS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th May 2005, 21:54
  3. Help Engine Management Light On
    By taj in forum TT/TT-S/TT-RS Forum
    Last Post: 13th January 2005, 20:07
  4. Engine Management Light
    By Tendaimwari in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th November 2004, 21:11
  5. Engine Management Light
    By StephenBogan in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th September 2004, 13:06
