Volks AutosJMB Retrofits
    Jan 2012
    Malton
    276
    CTS change on a AFN
    Dear Forumistas,
    So, Audreytoo doesn't show running temp properly. I thought I would start with the CTS as they seem to have a reputation for failure after some years. On the 2.5 this was a 10 minute job once I had stopped snapping the securing clips. When I got to have a look at the AFN engine it seems to be much less accessible. How much time should I allow to do the work and which bits do I need to remove to get access? AFN.jpg
    The little breather (?) pipe from the top of the EGR valve was disconnected - what effect would that have (what does it do?)
    cheers all,
    Tom
    Sliver 2000 1.9 Tdi AJM Se Auto Saloon cooking sherry but with CD Changer and now Bluetooth audio connection and boot based Tartan blanket. Now runs at 90 degrees like a good 'un
    Silver 2000 2.5 V6 Tdi Auto Quattro Saloon drowned on 7th August 2012 RIP
    Jul 2007
    London
    3,219
    You can leave it off,stops clogging the engine...
    FOR SALE:
  1. Replies: 2
    Last Post: 6th June 2011, 15:25
  2. changing the gearbox oil
    By ooooaudi in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th May 2003, 06:14
  3. When to change cambelt??
    By Joules in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th April 2003, 14:25
  4. Change of Car below 8K - any suggestions??
    By fraz in forum Other Brands & Models
    Last Post: 5th March 2003, 17:10
  5. Early oil change on a new Diesel
    By DMitch in forum Diesel forum
    Last Post: 19th February 2003, 17:58
