JMB RetrofitsAH Fabrications
    Nov 2012
    49
    Help! What have I broken??
    Hi guys,
    fiddling about getting the coolant hoses clamped up, and started the engine and some blue fluid leaked out of what looks like one of the injectors. I've managed to break off a braided hose that looks to connect each injector in series.DSC_0145.jpg
    What is this? Is it an expensive fix?
    Regards,
    Grant
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,138
    It may be the return pipe nipple or the feed pipe isnt quite sitting flush you are meant to replace the feed pipes if removed, you may get lucky and only have sliced the return pipe which is just 3mm id rubber hose.
  1. Help? what do I need to have a S-line front end Pics inside
    By bradus in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th June 2012, 15:12
  2. Newbie - Help what chassis do I have then?
    By VanishingPoint in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 19th August 2009, 16:51
  3. HELP! I have no boost!
    By Grant in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th December 2006, 10:46
  4. Have I broken it?
    By Kevint in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th August 2005, 22:09
  5. Come on guys help us have a good xmas party !!!
    By Markey in forum General Chat
    Last Post: 2nd December 2004, 22:31
