Badger5AH Fabrications
Results 1 to 8 of 8
    Jan 2011
    isle of lewis
    15
    Thumbs down help with my conversion problems.
    ok guys here they are.
    1,transponders are different.
    2,need to wire dbw or not.
    3,need to rewire dials.
    ok the plan was to put a 1.9 tdi 110 from a 1999 a4 avant into my 1.8 adr 1997 a4 avant.
    engine,fuel tank,lines,plumbing and everything is done other than whats above.
    now starting at no 1 the transponder(if thats what its called) on the back of the ignition barrel is different, 1997 has a long tapered bit that slots into the back of the barrel,1999 has a thin tapered part that does not reach the innards of the 1997 barrel.
    do i need to change the actual barrel cylinder too.
    no2 1997 had a cable throttle,1999 has dbw throttle.is my 1997 pre wired for dbw whereass they have hidden the plug.or do i have too wire this in.
    no3 the two plugs on the back of each dials are different to each other is this a matter of popping the pins and relocating to facelift plugs or is there more too it.
    any help atall guys and girls is much appreciated.
    also another downer to my day was that i found a hidden 1.9 tdi quattro sport 1997 that has been laying for a year and a half and the guy would not sell it.i was so so sad.lol.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,370
    You will have to change the ENTIRE wiring harness to make this work properly.
    no point farting around trying to patch bits in here and there when so much is different.
    TD5 Land Rover Defender build
    TDi Powerrrr
    Aug 2010
    North Devon
    405
    as kev says
    tony
    Jan 2011
    isle of lewis
    15
    will the 1999 loom fit my 1997 dash such as switches having the same plugs. reason being as i didnt want the facelift dash and ripped some of it out,aka broke some of it.lol
    Aug 2010
    1,540
    sorry for not helping but, never convert a car to one you can just go out and buy!
    "Stick a V8 in it!"
    15,370
    He didnt even need to buy it, he already had the complete car lol.
    bobo: if the interior in the 99 looks different (facelift) then you'll need to transfer over the dash cluster, AC panel, switches etc.
    Aug 2010
    1,540
    i cant imagine spending (read wasting) the shear amount of time/effort it would take to do what your doing.
    im presuming there was a reason why you dont just fix/use the 99 1.9 tdi and get rid of the wheezing "adr" 20v one?
    id break both cars and just go out buy the one you want when youve accumulated the cash!
    CraigG's Avatar
    May 2008
    188
    not to mention the hike in insurance costs for running a modified car over a standard one...
    Imola S4 - Bilstein B6 + Eibach Prokit, Anthracite BBS Pescara 18x7.5"
  1. Hi can any help with a coding problem
    By Troubs12 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th January 2012, 21:58
  2. Need help with oil cap problem
    By audi-tk in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th April 2011, 17:39
  3. Help with a running problem on boost please
    By S£ in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th January 2011, 17:31
  4. Help with a few problems please?
    By jzr172 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 30th January 2010, 08:18
  5. Any help with my horn problem please?
    By sulaiman in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th November 2009, 22:41
