Chris NottSky Insurance
Results 1 to 7 of 7
Thread: K&N Air Filter
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,679
    K&N Air Filter
    Has anyone used one of these? If so, is it a worthwhile mod for a 2.8 30V?
    K&N Clicky
    Danielson's Avatar
    Jun 2004
    UK
    704
    Re: K&N Air Filter
    you want to ask that over on audizine my friend, you may actually get a respone on there, its pretty dead in here lately. =( or is it jus me!!
    Jun 2003
    Hythe, Kent
    1,180
    Re: K&N Air Filter
    I'm not an expert but I've read many posts where people think an after market filter can reduce the life/performance of the MAF.
    Kev.
    Danielson's Avatar
    Jun 2004
    UK
    704
    Re: K&N Air Filter
    only if they are over oiled.
    fallmonk's Avatar
    Turbo Sport
    Jun 2004
    Glesga,home of the rain god!
    1,836
    Re: K&N Air Filter
    Hi mate , i fitted a K&n pannel filter a while back , works fine , no problems with the MAF , wot im told is you need to watch when you re-oil it , lets face it K&n are a huge company whey wouldnt be aloud to build some thing that could damage your engine ! gives you a slightly "raspy" noise , am told it will give a few(2or3bhp) just cause the engine breaths easier and if turbo model it helps power build quicker!
    Jun 2003
    Hythe, Kent
    1,180
    Re: K&N Air Filter
    Mick,
    You may well be right, but it's not a case of K&N building a filter that will damage your car. It's a case of Audi using a MAF which is prone to failure under normal conditions, let alone non standard ones.
    Kev.
    Jan 2004
    Northern New Jersey, USA
    91
    Re: K&N Air Filter
    my maf went at 60k i had a k&n fitted into the box at 53k when i did my power chip. whether or not the k&n screwed up the maf in 7k is still in the air, but with all the time and confusion it took to get the problem sorted out it was enough to make me go back to the standard mann oem filters
