Monster MotorsportVolks Autos
Results 1 to 15 of 15
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    2,870
    Coil upgrade harness (obsolete)
    Well ive just been in contact with TPS to get the coil upgrade harness 1J0971658L and its been made obsolete and replaced by two wires anyone no where i can source one in the uk rather than the one ECS tuning do ???
    Mods - Frankenturbo F4 Kit - THS Decat - Milltek - ECS Crank Pulley - 034 Snub + Bracket/Gbox Mounts - 1Z/S2 Clutch + Flywheel - 007p - ICM + EVAP Delete - S4 B6 345mm Brakes - 300mm Rear Brakes - Goodridge Hoses - LCR Splitter -S4 Bumbers + Skirts/Mouldings - OEM Xenons - Apikol Diff mounts - Polytek'd Rear Diff Mount
    To do - F21 Upgrade - 3" Maf/Saab red Injectors
    WANTED : Cheap 02/52 Passat 1.8T AWT Manual
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,900
    try 1J0971658M
    TD5 Land Rover Defender build
    Aug 2010
    2,870
    All utter bull**** lol got our parts lad to ring them back and they said 'we dont carry that 2 day order' 'can i order one ?' he said which they replied 'sure' someone obviously got something wrong lol probably our parts lad he can be abit numb at times.
    so i have one ordered for wednesday !!
    NineNails's Avatar
    Proud sponsor of the snack food industry
    Sep 2006
    North Wales
    577
    What's this harness all about then?
    2000 1.8t quattro Sport totally standard (ish)
    Aug 2010
    2,870
    To upgrade to the hitachi 'E type coils or 2.0T push downs with adapters im doing the bolt down option on saturday.
    "Stick a V8 in it!"
    14,900
    The harness is just a replacement bit of loom, for golf platform cars, which happens to include the coil pack connectors.
    Its handy to use to convert the earlier cars to use the newer coils though as it has all the plugs in the right place and plenty of wire to work with.
    Aug 2010
    2,870
    If im going to be running the E type bolt downs what plug gap would you guys recommened ???
    "Stick a V8 in it!"
    14,900
    standard? 0.8mm i believe
    Aug 2010
    2,870
    Is .032 suitable for these coils ive read .040 but iirc this is when running 2.0T coils ????
    "Stick a V8 in it!"
    14,900
    0.032" is just over 0.8mm which is the stock gap.
    Aug 2010
    2,870
    Can i increase the gap or am i best off running at 0.032" ???
    look whats just turned up !!!
    Aug 2010
    2,870
    Going to tackle the coil harness on saturday but have a few Q's as i want to get it right first time now looking at this diagram
    the four wires that go to the icm then come out to the coils can i splice in to the first four wires before the icm and pull the wiring out the existing loom to clean it up a bit also the ground for the icm i take it that it runs back through the loom and i just ground to the valve cover ?
    now it says to bridge pins two and four and create a new ground now wont the stock location ground for one of the pins be already there so i just need to bridge the other pin so in theory i could just put these four wires to the icm brown ground rather than grounding it on the valve cover or do these go with the valve cover ground (icm brown).
    im slightly confused with the icm ground if theres no icm why does it need to be grounded if it is the icms earth ???
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,354
    Pull the loom back is best way and double the old ICM earth back and stuff it on the valve cover too. The new coils for some reason use 2 earths, no harm in giving it them.
    Aug 2010
    2,870
    Right ive just stripped the new harness and marked out pins for each coil now pin 2 on the new loom is spliced and comes out as two brown wires (1 small & 1 big ) can i pin the big one and pin the icm earth wire and put them in my connector then ring the small one off on to the valve cover ????
    Aug 2010
    2,870
    Well been at it and SUCCESS !!!
    fired up first time and throttle response is alot better especially in high gears at low rpm no more misfiring now and idle is more stable.
    just a few pics
    old coils and valve cover.
    New valve cover and coils, wiring stripped.
    Old coil harness and icm wires pulled though old coils and icm.
    Icm location tidied up a bit.
    Citroen 16 way connector for easy removal of harness.
    and the finished product
  1. Do Audi sale Replacement coil pack harnesses
    By dre_S3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th September 2012, 13:52
  2. Headunit upgrade harness???
    By KejA3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th August 2012, 15:02
  3. coil pack wiring harness?
    By Splodge in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd November 2011, 22:09
  4. Upgraded igntion coil packs?
    By legal_ice in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd April 2010, 22:41
