Well ive just been in contact with TPS to get the coil upgrade harness 1J0971658L and its been made obsolete and replaced by two wires anyone no where i can source one in the uk rather than the one ECS tuning do ???
All utter bull**** lol got our parts lad to ring them back and they said 'we dont carry that 2 day order' 'can i order one ?' he said which they replied 'sure' someone obviously got something wrong lol probably our parts lad he can be abit numb at times.
Going to tackle the coil harness on saturday but have a few Q's as i want to get it right first time now looking at this diagram
the four wires that go to the icm then come out to the coils can i splice in to the first four wires before the icm and pull the wiring out the existing loom to clean it up a bit also the ground for the icm i take it that it runs back through the loom and i just ground to the valve cover ?
now it says to bridge pins two and four and create a new ground now wont the stock location ground for one of the pins be already there so i just need to bridge the other pin so in theory i could just put these four wires to the icm brown ground rather than grounding it on the valve cover or do these go with the valve cover ground (icm brown).
im slightly confused with the icm ground if theres no icm why does it need to be grounded if it is the icms earth ???
Pull the loom back is best way and double the old ICM earth back and stuff it on the valve cover too. The new coils for some reason use 2 earths, no harm in giving it them.
Right ive just stripped the new harness and marked out pins for each coil now pin 2 on the new loom is spliced and comes out as two brown wires (1 small & 1 big ) can i pin the big one and pin the icm earth wire and put them in my connector then ring the small one off on to the valve cover ????
