AH FabricationsChris Nott
Results 1 to 8 of 8
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,138
    Facelift headlight question (FL car)
    I have a set off facelift lights that are like new as the old ones are fairly dull so thought id replace them so it looks a bit cleaner now one off the lights has no adjuster motor how easy are they to swap out from my existing lights to the newish ones ??????
    Also got tge steering rack which will be going on today hopefully dont have the part number of it yet as its in packaging and quite manky with residue fluid but this one has no damper =)
    Aug 2010
    3,138
    No reply needed as ive sorted it after a bit off poking and twisting lol
    Aug 2010
    3,138
    Well got the headlights on and my god what a difference a set off clean clear lights does to the apperance and overall beam output of the car it look miles better glad i did them !!!
    Here from a while back -
    heres the manky dull n/s one -
    and heres the shiney clean o/s one -
    the o/s one is a depo light so is presumably not from 2000 but the n/s one is more or less same condition overall happy with the swap.
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,006
    Looks good mate.
    How did you get on swapping the motors over?
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    Aug 2010
    3,138
    The motor twists out then you have to push the motor at the top to pull the rod out from the headlamp as it sort of slots in a groove pretty easy when you look at. Going to tackle the rack this week sometime off work thursday/friday so may ask the boss if i can do it in works time save me wasting another saturday morning/evening as im not in work saturday.
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,006
    Quote Originally Posted by Bradderz_1988 View Post
    I often thought about using the motors from my PFL lights in the FL lights.
    Rack?
    Fast rack?
    Aug 2010
    3,138
    The steering rack is from a x reg TQS so has no damper where as mine has a damper the part number on it is 8d2 422 065 p. as the rack has play in it which is causing my steering to have a play spot so i constantly find myself making constant little adjusments with the steering wheel theres nothing in the uj so its pointing to the rack as ive just replaced all the control arms/TRE so finger crossed it will cure my problem and give me a bit better steering with the none damper rack.
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,006
    Damper?
    We got dampeners in our racks?
    Possible being a bit silly and simple.
    What do they do?
    its is across the range or a TQS thing?
  1. Replies: 2
    Last Post: 15th August 2012, 15:46
  2. Replies: 1
    Last Post: 21st July 2012, 10:25
  3. Pre facelift headlights question
    By Snash7 in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th June 2012, 20:49
  4. urgent facelift headlight and bulb question
    By A3tell in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th January 2012, 14:32
  5. Facelift owners with DRL's, headlight question
    By Sem in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd September 2009, 11:22
