Sky InsuranceChris Nott
Results 1 to 13 of 13
    Nov 2012
    Preston,Lancashire,UK
    help locate alarm horn
    Hi all,
    i am Newbie, i am trying locate the alarm horn on my Audi A4 saloon 1.9tdi year 2000(W).
    Appreciate with pictures and instructions please
    thanks in advance.
    spartacus 68's Avatar
    Dec 2008
    Aberdeenshire
    254
    Alarm overhaul
    On the avant it's located behind the trim on the passenger side in the load area. I'm assuming its the same for the saloon? if not it's on the opposite side. The alarm is a sealed unit, but it can be overhauled to replace the batteries. Link here: Audi A4/B6 Alarm Siren - Replace NiMH Batteries
    2002 A2 1.4 TDi SE (125k)
    2001 A4 2.5 TDi Avant Quattro Sport (155k)
    1995 80 TDi Avant SE (175k) Sold
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,374
    Its on the drivers side on all B5's after '98ish
    Open the cubby hole, lift out the central locking pump (its encased in a big block of foam) and look down and you'll see the siern tucked up against the chassis rail.
    TD5 Land Rover Defender build
    Nov 2012
    Thanks, i take it that the "cubby hole" is in the boot?
    "Stick a V8 in it!"
    15,374
    yeh, on a saloon you need to pull the carpet/boot lining up to get at it. Avants have a hatch thing.
    I notice your nearby, so if you need it scanned you can pop round and i'll take a look at it for you.
    Nov 2012
    Cheers, when are you available to scan ? PM me with details. In the meantime i had a look in the boot, there is black plate (12" diameter) which is bolted down on the boot floor near rear set NS, is this where the alarm horn is.
    "Stick a V8 in it!"
    15,374
    well i'm away from home until monday, but any time after that really.
    The circle youve found is the fuel pump hatch.
    If you look on the right hand side (drivers) of the boot, theres a little pocket thing, and the access hatch for the light cluster. You need to pull that whole carpet side/thing out and you should see the central locking pump encased in a big block of foam. Carefully lift that out, and the siren is down in the cavity.
    Jun 2011
    73
    I have had my A4 1.8t sport quattro for 5 years now and did not even realise there is an alarm horn - I have never heard the alarm go off or know how to set it, I am assuming the batteries are perhaps dead ? after reading the write up - something more for me to investigate and play with !!
    East Berkshire
    178
    It should set automatically when the car is locked. The horn has gone on ours, but the lights still flash if the alarm is set off . One of these days I shall replace the batteries !!
    ChrisG
    Arrkon's Avatar
    Midlands regional Moderator
    Oct 2010
    Coventry, West Midlands
    1,642
    Yeah, then internal batteries die/corrode. some have replaced the battery, others the unit...
    there is a "beep" available upon locking/arming too, but needs to be enabled in VCDS
    Currently rolling in a SKODA!!!
    East Berkshire
    178
    definately no beep.... her car and she doesn't like noises like that -- probably why I've been able to get away with not replacing the batteries for a number of years..... and nobody looks when an alarm goes off do they...!!
    ChrisG
    NineNails's Avatar
    Proud sponsor of the snack food industry
    Sep 2006
    North Wales
    579
    Not these ones anyway. Got to be the most pathetic car alarm I've ever heard lol
    2000 1.8t quattro Sport totally standard (ish)
    Arrkon's Avatar
    Oct 2010
    1,642
    BMW comes in a close second, They are really naff too...
  1. alarm horn location
    By mad cornish pastie in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th February 2011, 15:18
  2. Help locating / replacing engine mounts - pics please!!!
    By technics100 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 26th July 2010, 20:14
  3. Alarm horn location...?
    By S3 YEA in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th November 2006, 19:21
  4. 01134 - Alarm Horn - No communications
    By Stringster in forum VCDS (formerly VAG-COM) forum
    Last Post: 11th November 2006, 14:49
  5. Alarm horn location?
    By VAGMAN1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th June 2005, 16:44
