Chris NottMonster Motorsport
Thread: Wind noise
    Chriscooke's Avatar
    Clueless!
    Mar 2012
    Taunton
    406
    Wind noise
    I have an annoying problem with wind noise coming in from around the drivers door at sny speeds over 50mph.
    Are the door seals sold separately or does anyone know of any tricks to stop the air getting in?
    TDi Powerrrr
    Aug 2010
    North Devon
    405
    try adjusting the door frame in slightly.Remove the door car and the 4 torx bolts are then visible,2 front and 2 rear.Loosen them off,push the frame towards the car slightly,then tighten up.
    hth
    tony
    Chriscooke's Avatar
    Clueless!
    Mar 2012
    Taunton
    406
    Door frame? Is the door in two parts then with the window surround being separate? Will have a look at this when I get some time. Is the card easy to remove?
    Sorry about all the questions and thanks for the advice.
    TDi Powerrrr
    Aug 2010
    North Devon
    405
    The window and frame (including window mech) are seperate from the lower part.Door card is 2 small screws top front and rear,1 screw by the door handle,then pull that part of trim down to reveal another 2 screws,then pull the doorcard upwards.
    hth
    tony
    Chriscooke's Avatar
    Clueless!
    Mar 2012
    Taunton
    406
    Perfect. Thank you
  1. Wind Noise
    By TripleD in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th March 2009, 21:27
  2. A3 1.8T Sport - Wind Noise through vents?
    By Floob in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th July 2008, 19:59
  3. Wind noise on S3
    By DPM in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th July 2006, 10:39
  4. Wind Noise
    By imported_mav in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 24th May 2005, 21:01
  5. Wind noise
    By Kevint in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd April 2005, 11:11
