Badger5EM Tuning
Thread: FM aerial
    Mar 2004
    22
    FM aerial
    Does anyone know where the antenna is located on aerial is located on an 97 A4? I get really poor signal, wanted to check it was ok [img]/ubbthreads/images/graemlins/confused.gif[/img] [img]/ubbthreads/images/graemlins/confused.gif[/img]
    madkebab's Avatar
    Dec 2003
    South West
    396
    Re: FM aerial
    Its located in the rear screen. You will need a signal booster to get better reception. I think caraudiodirect do them for about 15.
    Mar 2004
    22
    Re: FM aerial
    where does the wire connect to in the rear screen? can I put a booster there?
    Jul 2005
    2,488
    Re: FM aerial
    well, the booster requires power, so I'd connect it up in the console for a hidden installation.
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,695
    Re: FM aerial
    IIRC correctly, it sits in line between the cable & the HU
