Chris NottMonster Motorsport
    Soupie69uk's Avatar
    Owner
    Mar 2004
    Edinburgh, Scotland
    2,698
    1.8T system pressure test
    Hi has anyone got any instructions on how to pressure test the turbo system on 1.8T?
    Think I may add this to my service routine just to check for leaks etc.
    I have access to an airline so would just need the appropriate equipment.
    A4 1.8T Quattro, FMIC, Coilovers, B&M short shift, 312mm Brakes, Stage 4 clutch, Awe Gauge, Uprated antiroll bars, plus more bits. Pics Here
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    2,866
    I made my own and used a 19 mm wheel nut to blank off the pancake pipe hole my tester consisted off a cap to blank off the extractor ducts at work (shhhh) and a tyre valve pulled through and my boost gauge also pops out and can disconnect it and reconnect to the manifold so i can keep an eye on pressure in the bay whilst charging the system with a tyre gauge.
    heres mine -
    Mods - Frankenturbo F4 Kit - THS Decat - Milltek - ECS Crank Pulley - 034 Snub + Bracket/Gbox Mounts - 1Z/S2 Clutch + Flywheel - 007p - ICM + EVAP Delete - S4 B6 345mm Brakes - 300mm Rear Brakes - Goodridge Hoses - LCR Splitter -S4 Bumbers + Skirts/Mouldings - OEM Xenons - Apikol Diff mounts - Polytek'd Rear Diff Mount
    To do - F21 Upgrade - 3" Maf/Saab red Injectors
    WANTED : Cheap 02/52 Passat 1.8T AWT Manual
    Soupie69uk's Avatar
    Owner
    Mar 2004
    Edinburgh, Scotland
    2,698
    Do you have any pics of where you link that up on the engine and where you blank off?
    Also what size do we need? I see kits on ebay for sale to test.
    Aug 2010
    2,866
    Well mine fits straight on to the maf which is 2.75" as no airbox on my car which was a miracle finding something the exact size at my works lol where you blank it off is on the TIP where the plastic hockey puck valve is and take off the oil filler cap thats it just dont go past 15-20psi you only want it in the boost level range of our cars so 15 should be more than enough unless your running higher boost id go slightly past that.
  1. Pressure testing a turbo system...
    By nick4501 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th December 2010, 15:15
  2. Coolant System Pressure Testing
    By Pabs in forum Awesome GTI
    Last Post: 18th November 2010, 16:10
  3. Pressure testing boost system?
    By Speedy Steve in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th September 2009, 18:08
  4. Pressure Testing Turbo Hoses.
    By jm-baker in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th March 2007, 19:30
  5. pressure test and surging
    By mac1403 in forum A4/S4 forum(B5 Chassis)
    Last Post: 5th November 2006, 20:36
