Badger5EM Tuning
Results 1 to 13 of 13
    NineNails's Avatar
    Proud sponsor of the snack food industry
    Sep 2006
    North Wales
    579
    Quick connect heater matrix hose
    The one that connects to the plastic flange pipe at back of head.
    Does anyone know the size of the sealing o ring just inside the pipe?
    Getting desperate to stop it leaking and can't get to the dealers for one
    2000 1.8t quattro Sport totally standard (ish)
    NineNails's Avatar
    Sep 2006
    North Wales
    579
    Also, is there supposed to be anything else inside that connection? It seems a bit not right that all that seals the connector is an o ring on the pipe spiggot. I've not lost a rubber washer out of there or something have I?
    B5 BIKER's Avatar
    Jul 2011
    GALWAY, EIRE
    241
    no, all that is in there is the o-ring.
    mine was leaking and when i opened it a few weeks ago the ring came out in 6 pieces.
    dont know how it wasnt washed away.
    i just got 10 different o-rings from a local auto factors for the princely sum of 2 euro.
    used the one that i thought fitted best inside the pipe - no leaks now.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,389
    Audi dont sell the seal sepreately either and theres nothing in ETKA.
    You sure its not a cracked flange?
    TD5 Land Rover Defender build
    NineNails's Avatar
    Sep 2006
    North Wales
    579
    Thanks for the input lads.
    I'm hoping the flange is not cracked Kev but it's kind of hard to have a good look back there. I want to try the easy things first The coolant is dripping off the bottom of the hose so I thought I'd try an o ring in there. I have a new cts to fit too so that will rule out that o ring. If it still leaks then it's gotta be the flange. Looks a tw*t of a job so wanted to avoid if possible mate
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,138
    My housing had a hair line crack on it just at the bottom of the bend.
    if you look at this pic were the bottom 10mm is if you look to the left of it and up abit you can see a circle just slightly from when its been molded mine was leaking there.
    "Stick a V8 in it!"
    15,389
    mine was cracked underneath too.
    NineNails's Avatar
    Sep 2006
    North Wales
    579
    What's the flange like to change then, much pain?
    "Stick a V8 in it!"
    15,389
    I did mine with the engine out, but tbh its only two bolts so i cant see it being too difficult?
    Aug 2010
    3,138
    Piece of piss two bolts and slides off the pipe just dont drop one of the bolts on to the gearbox couldnt find it at all so got a bolt and washer bleed it up and then spotted it while checking for any leaks and threw it back in OCD i no lol when you get a new one you will need a new bung and clip i also changed my temp sensor to the green instead of blue. I also change the header tank so it was fresh and pink
    NineNails's Avatar
    Sep 2006
    North Wales
    579
    Changed o ring and still leaking
    I have a new flange but it has two sensor ports. No problem I thought. I can use the old cts as a bung in the spare port. Pulled clip out of cts and promptly lost it down the back somewhere, so can't do it now untill next weekend when I can get time and a new clip.
    Another problem is I have the wrong cts. I recieved a blue 4 pin square cts. My cts is black and a D shape 4 pin. I can only see green ones for sale, is this ok??
    "Stick a V8 in it!"
    15,389
    All new ones are green.
    Only buy Genuine CTS from the dealer (or TPS) the saving isnt worth the hassle if it then starts acting odd.
    NineNails's Avatar
    Sep 2006
    North Wales
    579
    Just to update: All fixed
    Wasn't too bad to do, with minimal damage to arms. There is a moulding seam along the pipe and that's where mine had been leaking. I'd also got some better, slightly fatter 'O' rings for the heater hose and a proper blanking plug for the spare port. I had to buy 10 'O' rings so if anyone wants one just PM me.
    For the search engines out there... Heater pipe o ring size for a good tight fit is 21mm ID x 4mm cross section
    Thanks for all the help as ever lads
    Si.
  1. S4 Top water hose connector to heater matrix
    By andybnwc in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th March 2010, 22:15
  2. Heater Matrix
    By harps21k in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th May 2009, 18:19
  3. Golf Mk2 Heater Matrix!
    By jojo in forum Volkswagen and other VAG
    Last Post: 28th March 2007, 03:51
  4. Heater matrix - no hot air!!!
    By RickT in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th February 2007, 13:45
  5. changinf heater matrix... how?!
    By imported_mattsavage in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st December 2004, 16:47
