Chris NottAH Fabrications
    Apr 2010
    48
    Very quick 1.8 non T thermostat fitting question.
    Firstly is there a paper gasket between the hoses? There is on my old one but thats knackered after the swap, but none of the new gaskets fit. And where does the oring go, before the stat in the pump or after? Ive heard before the stat in the pump but the diagram shows after with no sign of a paper gasket.
    http://www.vagcat.com/p/B156/121100.png
    Help!
    NineNails's Avatar
    Proud sponsor of the snack food industry
    Sep 2006
    North Wales
    579
    There's no paper gasket, just the 'O' ring. Order is... Thermostat in, then 'O' ring then plastic housing. 'O' ring should sit in a groove around the housing but the trick is that you've got to assemble it all with the hindrance of gravity lol
    HTH
    2000 1.8t quattro Sport totally standard (ish)
  1. 2009 Headlamp Retro Fit Question Non Xenon
    By Farhan in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd March 2011, 16:51
  2. Very Quick question...............
    By foxterrier in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th July 2010, 12:39
  3. I take it I need a thermostat fitted.
    By Jason-Con in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 22nd January 2010, 11:11
  4. Very productive day - Milltek sorted, Fuel pump fitted & Stage 2+
    By mattandrew in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th December 2009, 23:07
  5. Thermostat fitting guide
    By jiggaman in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th November 2009, 10:28
