So in fitting a control arm had to remove the whole damn hub assembly to drill the pinch bolt out. Couldnt get the ABS sensor out, smashed it up trying to get it out from the inside, so had to cut it off.
Replace with used genuine or new pattern part?
Mines an early facelift avant, would this fit, hes not a million miles away. VW PASSAT B5 SALON 2001 2.0 FRONT ABS SENSOR | eBay
Cheers.
Cheers.
