Sky InsuranceEM Tuning
    Jan 2007
    Motherwell
    10
    Anyone with a 90hp AHU engined car? I need help with vacuum pipe locations.
    I've just rebuilt my friends 2000 w plate 1.9 TDi. It's the AHU engined 90bhp version. There are vacuum pipes at the bulkhead, and I can't figure out where on of the goes. Can anybody help? I know one of the goes to the egr, and another to the air filer housing, but there is another not attached to anything which I can't figure out. The turbo isn't cutting in, and I hope the 2 are related.
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    2,877
    Vnt on the turbo or the turbo pressure electrovalve ???
    Mods - Frankenturbo F4 Kit - THS Decat - Milltek - ECS Crank Pulley - 034 Snub + Bracket/Gbox Mounts - 1Z/S2 Clutch + Flywheel - 007p - ICM + EVAP Delete - S4 B6 345mm Brakes - 300mm Rear Brakes - Goodridge Hoses - LCR Splitter -S4 Bumbers + Skirts/Mouldings - OEM Xenons - Apikol Diff mounts - Polytek'd Rear Diff Mount
    To do - F21 Upgrade - 3" Maf/Saab red Injectors
    WANTED : Cheap 02/52 Passat 1.8T AWT Manual
    Greeny233's Avatar
    Mar 2011
    Leuchars
    550
    Follow Greeny233 On Twitter
    There is a vacuum valve mounted on the underside of the hard plastic turbo pipe which runs around the back of the engine, it should run to that. Should sort the boost issues, my old B5 1.9 AHU had a boost problem and it was this valve which was the problem.
    Chris "the machine" Green.
    2004 Audi A4 1.9tdi Sport Quattro Avant
  1. New on here.. need help with engine ECU
    By scottyaudi in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th September 2011, 13:22
  2. need help with this..anyone?
    By audi_a3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th January 2011, 15:47
  3. Need help with buying A4
    By samku in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd October 2004, 13:15
  4. Engine swap - need help with codes
    By Pincher in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th August 2004, 22:33
  5. Please I need help with spacers!!!
    By nianmuzik in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th April 2003, 22:44
