Sky InsuranceVolks Autos
Results 1 to 13 of 13
Like Tree1Likes
  • 1 Post By Sulli79
Thread: Help got a slight knock noise on drivers side if you go over pit hole or a big bump ?
    Jan 2012
    41
    Can anyone help I got a 99 a4 1.8t and got a knocking noise when I go over hate bump or pothole ?? Any ideas it's seems only to be drivers side? Maybe a bush or mount ? Just got a4 from having a a3 1.8t before so don't know much about common probs with the a4 would appreciate any help on this one? Also where is Ecu box as need to put a amp wire through but was told go through Ecu??
    thanks
    Sulli79's Avatar
    Oct 2010
    Surrey/Berkshire
    497
    Possibly front control arms, common problem, get a decent set to replace, meyle or lemforder, and do the full set or you will forever be chasing knocks! Ecu is top left below drivers windscreen wiper, goes straight into the cabin
    1999 1.8TQS Saloon in Black/Dirt
    1999 1.8TQS Saloon in Silver Breaking
    Jan 2012
    41
    They the wish bones ?? Lower arms ? Suspension arms ?
    Sulli79's Avatar
    Oct 2010
    Surrey/Berkshire
    497
    sort of its not like a McPherson strut set up, Audi went for a full independent set up so it has upper and lower control arms, they are a bit **** and the bushes in these tend to wear and cause knocks and general pants handling, cheapy ebay sets can be had for about a hundred quid, but it is money wasted as they seem to last a few thousand miles before failing again.
    go with one of the brands from above and you should be ok, not cheap though, about 300, but thats a complete set and will freshen up your front end. whilst its in bits subframe bushes do wear out and cause some issues
    gedi likes this.
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,138
    Yep control arms will be the problem here it will be worth your while and the cars for that matter ive just ordered a set of meyle hd control arms off ebay £340 in total but they come with a 4 year Guarantee so better than any cheap **** out there as my arms seem to just dictate which way they want the car to go.
    Oct 2008
    Glasgow
    431
    Well worth considering the 034 Motorsport arm kit - 034 Motorsport Control Arm Kit Track Density audi b5/c5/passatA4/S4/RS4/A6/S6/RS6
    As said it is better to replace the whole lot or you will be chasing knocks.
    Aug 2010
    3,138
    Nice sales pitch there hektor lol
    quick one do you sell the coil adapters in anodisedblack for the 2.0T coils for AEB/AJL ENGINE if so cost posted cheers mate.
    Oct 2008
    Glasgow
    431
    Quote Originally Posted by Bradderz_1988 View Post
    hahaha not a sales pitch, just another option to consider...
    Oct 2012
    26
    could bethe suspension top mounts....
    Nessy's Avatar
    VW + Audi mad
    Oct 2005
    Bridgend, South Wales
    617
    Quote Originally Posted by oldbanger View Post
    My money is on one of the suspension arms being the culprit, as has already been said.
    I had a very similar issue a few months ago that drove me mad , eventually it was traced to a slightly worn balljoint on the the rearmost bottom suspension arm (the big curved expensive one!) , it was replaced and silence resumed.
    I renewed all 4 shocks recently and as part of the process also renewed the front top suspension mounts which on the A4 are nothing like the bearing versions found on the Audi 80 and other VAG group cars that swivel with the steering etc.
    The old ones that had done 215k miles that came out looked as good as the identical new Lemforder ones I replaced them with, so I don't think the strut top bearings on the A4 have a tough time at all.
    '99 Ming Blue A4 Avant TDi SE 110 + Dragon Performance Tuning Box
    Factory sunroof / Cruise / Aircon + Climate / Royale Blue leather
    '72 1302LS Karmann Beetle Cabrio Silbermetallic
    '63 Karmann Ghia Sunroof Coupe Pacific Blue
    Apr 2010
    48
    I had a knocking and changed out the track rod end for the MOT and knocking went, never considered the TRE
    _G_
    _G_'s Avatar
    Jul 2011
    869
    My front right suspension all of a sudden started squeaking....noticed it on slow speed bumps. The squeak is like closing a rusted door...kinda squeak.
    Took the wheel off and found nothing. Traced it down to spring area. I can replicate the squeak when I press down on the front right. Does anyone have any idea what to check next?
    are these control arm bit things dangerous if left for too long? I want to know how long I can go without touching them. I'm easy over the pot holes. Just did a few major repairs costing £300.
    _G_
    _G_'s Avatar
    Jul 2011
    869
    bump
  1. Vmaxx coilovers slight knocking noise 2.0T quattro
    By jakeward46 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th November 2011, 15:43
  2. Slight Knocking Noise - Opinions?
    By Geoff-R in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th May 2011, 13:55
  3. Rotational Rattling Noise From Drivers Side Front Wheel...Please help!
    By Nickpap in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd February 2010, 21:04
  4. Banging noise on driver side.
    By hardytangi in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 31st January 2010, 18:10
  5. What is that slight knocking noise!?
    By Prince Ace in forum RS6 Forum
    Last Post: 21st January 2008, 12:09
